Need Noobs Guide?
This is a complete Noobs guide around here anywhere. I do mean NOOBS. I am trying to setup Pihole for the first time and I keep getting a error with FTL when it installing on Raspbian Lite. Tried 2 different Pi's, several different Ethernet cables, different ether ports, several different versions on Raspbian Lite. Opened the ports on the router, Mac and windows. Still getting the same error. This is over my head and would love some help.
why not post the errors you're getting?
to be completely honest, I'm not even sure if I am even doing it right to start with. At least with a full start to finish NOOBS guide I can figure out what I am doing wrong
Here is a guide I wrote and posted on Reddit. In the near (or semi-near) future this will be in the Pi-Hole documentation in the guide section.
https://www.reddit.com/r/pihole/comments/9y9e9w/simple_guide_to_setting_up_a_pi_zero_w_and/
You should not be opening any ports on the router. Pi-Hole is designed to run behind the protection of your router, and this is defeated when you open ports on the router for Pi-Hole (especially port 53 where DNS traffic travels).
When I try to ssh into Pi ssh pi@192.168.2.31
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:Yf9Flszemd4JwQZaZnZZhz7ScIIf5FlcsLp2z7NaXjU.
Please contact your system administrator.
Add correct host key in /Users/ianedwards/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /Users/ianedwards/.ssh/known_hosts:2
ECDSA host key for 192.168.2.31 has changed and you have requested strict checking.
Host key verification failed.
Followed the guide as per link.
[ ] Downloading and Installing FTL
Error: Unable to get latest release location from GitHub
[ ] FTL Engine not installed
Same thing, fresh install
sudo edit /etc/resolv.conf gives me this
Generated by dhcpcd
/etc/resolv.conf.head can replace this line
/etc/resolv.conf.tail can replace this line
No lines to change ip
