the pihole is installed on a ubuntu 20 machine connected to a ubiquiti router
pihole is working fine and then when I open a browser whit 8 pages it crash and dont resolve, dont get response for the forwarder request, try dig and dont get response when the problem is present other time it work fine
You'll also need to check your networking, one of the upstreams you have chosen does not work (google) and that's pretty important to have working:
[✓] aff.naughtyconnect.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] aff.naughtyconnect.com is 0.0.0.0 via Pi-hole (10.0.0.10)
Failed to resolve doubleclick.com via a remote, public DNS server (8.8.8.8)
this happen went it dont resolve or when the problem happen
other times it pass
[✓] waterdiepattern6.live is 0.0.0.0 via localhost (127.0.0.1)
[✓] waterdiepattern6.live is 0.0.0.0 via Pi-hole (10.0.0.10)
[✓] doubleclick.com is 172.217.2.206 via a remote, public DNS server (8.8.8.8)
dont understand what is happening I change noting before I have the pi on a virtual machine and dont fail then I get a NUC and want to run in it but now this happen
Changing from a VM to a NUC is a big change. Did you properly update the static IP address for the NUC and for Pi-hole? Does the NUC have a consistent network connection? Is there a new route for the NUC vs the VM? Did the VM's hypervisor handle routing that needs to be done differently now that you're using a dedicated device?
thank you so much, think the router is doing a loop reverting all on it and configure it again appear to solve the problem on test now to see if the problem is solve, loading the 20 pages browser seem to work now
