Issue / Problem
I am seeing the following Error when running sudo pihole -up
: Could not update local repository. Contact support.
Potential Cause
Could this be to do with the fact that I have added the 'SpeedTest Mod' to my PiHole dashboard?
From the log below I can see that the 'Web Interface' is the only thing that requires updating.
Additional information from the command line
Below is a full read out from the command line when I runsudo pihole -up
$ pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] Web Interface: update available
[i] FTL: up to date
[i] Pi-hole Web Admin files out of date, updating local repo.
[✓] Check for existing repository in /var/www/html/admin
[i] Update repo in /var/www/html/admin...
Please could someone advise me on how to fix this. Thank you
I am not familiar with the speedtest mod, but this may be the source of the problem. Your debug log doesn't show any problems that should prevent Pi-Hole from updating.
This is worth a try. After you remove it, you can run pihole -r and select repair and if that completes then you should be able to update. If not, we can try walking you through clearing out your local repository and drawing a fresh new one.
I would also contact the person who wrote and maintains the SpeedTest mod and see if they can help you get your Pi-Hole updated.
Ask the maintainer of the speed test modification. They wrote the script that changed the repository to be off the Pi-hole maintained one. They should be able to tell you how to fix the situation their script put you in.
