Are you running any software on that particular client that could interfere with DNS resolution? Like Avast real site or any other 'advanced' malware protection software?
Yes, I am using Avast and Malwarebytes
Disable them and try again.
Disabling Avast fixed the issue. Do you know if there is a setting to get around Avast DNS protection.
I'm not using Avast, so I can't tell except not using the software or this particular function.
Found an article. Just in case someone else is having issues with Avast
https://support.avast.com/en-ww/article/Use-Antivirus-Real-Site#pc.
I have disable Real Site and left everything else on, and blocking works now.
Thank you for your help.
We have all been over-logging!! South Park had an episode about this.
At some point you'll see enough to just not have to see it as much and just do what we used to do before the turn of the century: imagination.
Helps stimulate creativity amd uses a lot less electricity from outside power plants. Win-Win for everyone.
Agree, @low_rider I was really surprised at how much traffic my devices were sending. At least I can stop most of it and in the process take care of unwanted site access.
Thanks you for your help @yubiuser
Thank you for your help @jfb
