Naming Devices
Folks,
A useful feature of the BT modems is being able to name your network devices. Makes for very easy monitoring.
Appreciate Pi-Hole's DHCP server lists machine names but most android devices just show as android followed by some obscure number.
Friendly names would be an excellent addition.
Geffers
This is already available :slight_smile:
Requirement: You made sure that the device will always get the same IP address (add a static lease in DHCP server).
Then, add this device with the name you like in /etc/hosts on your Pi-hole, e.g.,
192.168.2.125    android-cell
either wait until the next full hour (once an hour client host names are updated internally) or restart pihole-FTL and voilà:
or
Brilliant, I'll check that tomorrow.
Thanks for quick reply,
Geffers
@Geffers Did it work as expected?
I am so sorry for not responding, yes, it worked perfectly but I started to have trouble with one device on my network which was losing connection for no obvious reason so temporarily I reset my network back to original DHCP.
It certainly did work and I intend to go back to that when I have resolved my current problem which I am sure has nothing to do with Pi-Hole's DHCP.
Once again, apologies for not getting back,
Geffers
