Hello,
my pi-hole does not working properly.
On this website: https://fuzzthepiguy.tech/adtest/
I can see all the ads when I disable AdBlock on pc or when I visit the site via phone.
Since installing I have enabled DHCP server on pi-hole and turn it off on my router.
Before enabling DHCP I had 0 Queries Blocked for more than 24hours running.
From a client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
