Multiple IPs have same Hostname in "Top Clients" after filling "custom.list"
i'm using pihole in a podman container in a proxmox vm.
DHCP is done from my router.
Everything worked as expected.
But after filling "pihole/etc-pihole/custom.list" with some "ip hostname" combinations:
https://i.imgur.com/sWfTDwm.png
i ended up with different IPs having the same Hostname in the Dashboard:
https://i.imgur.com/iU6AOX1.png
  • Docker Tag [2023.05.2]
  • Pi-hole [v5.17.1]
  • FTL [v5.23]
  • Web Interface [v5.20.1]
Showing the correct hostname for the given IP in "custom.list"
Different IPs are showing with the same hostname in the Dashboard
https://tricorder.pi-hole.net/KlO1m6JC/
Does your observation still persist?
If your Pi-hole did acquire local hostnames via alternate sources prior to your custom.list edits, the UI may still have reflected that.
Also, did you restart your Pi-hole after manually editing custom.list?
Note that Pi-hole would also allow you to edit Local DNS records via its UI.
there shouldn't been any alternate sources.
I alread flushed logs / network table, restart dns and restart system ...
And evan after removing the entries in the custom.list. i have the same problem ...
will destroy and recreate the docker container ...
Hi all, FYI
i think i finally found the error ...
i pointed the "REV_SERVER_TARGET" to the IP of the pihole server instead of my Router ...
facepalm
sorry for that :>
