The issue I am facing:
Getting incorrect DNS resolution of the PIHOLE itself from other networks.
For example on a host on the DMZ network when I query dns01.lan, the LAN name of the DNS01 IP, it comes back with the DMZ IP address.
$ for i in lan iot dmz guest; do echo -n "dns01.$i: "; dig @192.168.220.8 +short dns01.$i; done
dns01.lan: 192.168.220.8 <- INCORRECT, should resolve back as 192.168.14.8
dns01.iot: 192.168.24.8 <- CORRECT, this is the IP of the IOT interface
dns01.dmz: 192.168.220.8 <- CORRECT, this is the IP of the DMZ interface
dns01.guest: 192.168.215.8 <- CORRECT, this is the IP of the GUEST interface
When I jump to another device on say IOT or GUEST they do the exact same thing and the dns01.lan always comes back as the IP of the dns.DOMAIN VLAN.
How do I make it so dns01.lan, or the pihole itself, doesn't do this and provide the proper IP?
Details about my system:
I have a pihole running with four interfaces via VLAN. Here is the break down:
eth0 - LAN - 192.168.14.8
eth0.30 - IOT - 192.168.15.8
eth0.40 - DMZ - 192.168.220.8
eth0.50 - GUEST - 192.168.215.8
I did this so I didn't have to cross the firewall for DNS requests and then on the pihole I block non-DNS services on the IOT, DMZ, GUEST networks except tcp/udp 53.
DHCP, on the pfSense firewall, hands out the local .8 for the respective subnet.
I also do the following for my internal networks:
root@dns01:/etc/pihole# cat /etc/dnsmasq.d/99-tuning.conf
# Fix PLEX
rebind-domain-ok=/plex.direct
# Increase max from 150 to 1024
dns-forward-max=1024
# settings to extra to be able to catch the ip of the requesting host
log-queries=extra
# Send local zones to Firewall for resolution
server=/lan/192.168.14.1
server=/14.168.192.in-addr.arpa/192.168.14.1
server=/iot/192.168.14.1
server=/24.168.192.in-addr.arpa/192.168.14.1
server=/dmz/192.168.14.1
server=/220.168.192.in-addr.arpa/192.168.14.1
server=/guest/192.168.14.1
server=/215.168.192.in-addr.arpa/192.168.14.1
Nothing, just switching back to pihole after a while and never used this mutli-vlan configuration before.
