If the domain and client query/filter boxes could be moved to the top of the page it would be much easier then having to scroll to the bottom of the page, especially when I set the number of entries to 100 or all.
Thank you.
Thank you.
As a possible solution/work around, the page down/end buttons on keyboard could be used. Not clear what device is being used, but even an iPad with a keyboard can do this.
yes, it’s a possible workaround but why not have it on the top?
unclear why all other pages have the search field on top,
Thank you for your kind reply.
Now I noticed the Advanced filtering on top has a search box but it requires a few clicks to execute a search.
@tweiner You have my vote to move the bottom “instant search” filter box to the top.
Yep, no idea why this was moved. It's annoying. Bring it back to the top so evolved humans can use it easily
