I was hoping to use Pi hole with monolithic cache on the same hardware with same or different docker containers. Monolithic usage 443, 53 and 80 ports.
Is it possible?
I'm pretty new to docker usage.
Thanks in advance
Is it possible?
Thanks in advance
Were you able to find any solution since then?
This actually is possible, and I've been running this with Pi-hole for about a year.
Ideally you would assign a secondary IP address for your monolithic
and sniproxy
containers.
You don't need to run the lancache-dns
container, there's a script that you can utilise to generate a dnsmasq based output which you can use with Pi-hole.
Sorry to bring up an old post, but is there a tutorial on how to do this, I’ve been struggling to get it working how it should for a while.
I’ve already got two IPs as i have to Ethernet ports, i currently have pihole as the upstream DNS for lancache but it either doesn’t work or is incredibly slow!
an this script ive seen mentioned in a few places seems to be my last hope.
