modem under pihole it's not protected
hi all, when i check the lists of the devices under pihole in my lan i got the modem's ip that is not under the 'protection' of the program. it appears like this:
ip modem
i wanted to know if there is a way to got the screen green since i have another router in the house which takes the signal from this one, so i would like to put this modem under pithole in order to get the protection also in the other router.
the screen should be green
the screen is red
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2020-06-21:20:24:10 debug log has been initialized.
[i] Core: v5.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v5.0-0-g4d25f69
[i] Web: v5.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v5.0-0-gb86e4a3
[✓] FTL: v5.0
[i] 1.4.55
[i] 7.4.3
[✓] Ubuntu 20.04 LTS
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[i] x86_64
[✓] IPv4 address(es) bound to the enp3s0 interface:
   192.168.1.26/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the enp3s0 interface:
   fe80::cd7f:4520:6a1e:e85d does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   * Pinging 192.168.1.1...
[✓] Gateway responded.
[80] is in use by lighttpd
[::1]:631 cupsd (IPv6)
127.0.0.1:631 cupsd (IPv4)
[53] is in use by pihole-FTL
[✓] www.controle-technique-64.xyz is 0.0.0.0 via localhost (127.0.0.1)
[✓] www.controle-technique-64.xyz is 0.0.0.0 via Pi-hole (192.168.1.26)
[✓] doubleclick.com is 216.58.205.78 via a remote, public DNS server (8.8.8.8)
[✓] lighttpd daemon is active
    BLOCKING_ENABLED=true
    PIHOLE_INTERFACE=enp3s0
    IPV4_ADDRESS=192.168.1.26/24
    IPV6_ADDRESS=
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=true
    DHCP_ACTIVE=true
    DHCP_START=192.168.1.201
    DHCP_END=192.168.1.251
    DHCP_ROUTER=192.168.1.1
    DHCP_LEASETIME=24
    PIHOLE_DOMAIN=lan
    DHCP_IPv6=true
    DHCP_rapid_commit=true
    DNSMASQ_LISTENING=single
    PIHOLE_DNS_1=8.8.8.8
    PIHOLE_DNS_2=8.8.4.4
    DNS_FQDN_REQUIRED=true
    DNS_BOGUS_PRIV=true
    DNSSEC=false
    CONDITIONAL_FORWARDING=false
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity List and Database
-rw-rw-r-- 1 pihole pihole 112099328 giu 21 20:02 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
   property              value
   version               12
   updated               1592749265
   gravity_count         1564678
   Last gravity run finished at: dom 21 giu 2020, 16:21:05, CEST
   ----- First 10 Gravity Domains -----
   localhost.localdomain
   01mspmd5yalky8.com
   0byv9mgbn0.com
   analytics.247sports.com
   www.analytics.247sports.com
   2no.co
   www.2no.co
   logitechlogitechglobal.112.2o7.net
   www.logitechlogitechglobal.112.2o7.net
   30-day-change.com
*** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0           1  Default                                             2020-06-18 23:01:44  2020-06-18 23:01:44  The default group
   id    type  enabled  group_ids     domain        date_added           date_modified        comment
   1     0           1  0             bit.ly        2020-06-21 16:28:30  2020-06-21 16:28:30
*** [ DIAGNOSING ]: Clients
   id    group_ids     ip        date_added           date_modified        comment
   1     0             192.168.1.1        2020-06-21 18:02:09  2020-06-21 18:02:09
   2     0             127.0.0.1        2020-06-21 18:02:16  2020-06-21 18:02:16
*** [ DIAGNOSING ]: Adlists
   id    enabled  group_ids     address        date_added           date_modified        comment
   1           1  0             https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts                                      2020-06-18 23:01:44  2020-06-18 23:01:44  Migrated from /etc/pihole/adlists.list
   2           1  0             https://mirror1.malwaredomains.com/files/justdomains                                                  2020-06-18 23:01:44  2020-06-18 23:01:44  Migrated from /etc/pihole/adlists.list
   3           1  0             https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt                                      2020-06-18 23:01:44  2020-06-18 23:01:44  Migrated from /etc/pihole/adlists.list
   4           1  0             https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt                                            2020-06-18 23:01:44  2020-06-18 23:01:44  Migrated from /etc/pihole/adlists.list
   5           1  0             https://raw.githubusercontent.com/CamelCase11/UnifiedHosts/master/hosts.all                           2020-06-18 23:03:30  2020-06-18 23:03:30
   6           1  0             https://raw.githubusercontent.com/hectorm/hmirror/master/data/adaway.org/list.txt                     2020-06-18 23:03:55  2020-06-18 23:03:55
   7           1  0             https://raw.githubusercontent.com/hectorm/hmirror/master/data/adblock-nocoin-list/list.txt            2020-06-18 23:04:07  2020-06-18 23:04:07
   8           1  0             https://raw.githubusercontent.com/hectorm/hmirror/master/data/adguard-simplified/list.txt             2020-06-18 23:05:35  2020-06-18 23:05:35
   9           1  0             https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt                            2020-06-18 23:06:26  2020-06-18 23:06:26
   10          1  0             https://v.firebog.net/hosts/AdguardDNS.txt                                                            2020-06-18 23:06:33  2020-06-18 23:06:33
   11          1  0             https://filtri-dns.ga/filtri.txt        2020-06-18 23:06:43  2020-06-18 23:06:43
   12          1  0             https://raw.githubusercontent.com/anudeepND/blacklist/master/CoinMiner.txt                            2020-06-18 23:10:31  2020-06-18 23:10:31
   13          1  0             https://raw.githubusercontent.com/anudeepND/blacklist/master/facebook.txt                             2020-06-18 23:10:41  2020-06-18 23:10:41
   14          1  0             https://raw.githubusercontent.com/andyts93/pihole-italian-list/master/adlist.txt                      2020-06-18 23:15:55  2020-06-18 23:15:55
   15          1  0             https://www.sunshine.it/blacklist.txt        2020-06-19 09:13:57  2020-06-19 09:13:57
   16          1  0             filtri-dns.ga/filtri.txt        2020-06-21 20:02:43  2020-06-21 20:02:43
-rw-r--r-- 1 root root 54 giu 21 16:21 /etc/pihole/local.list
   192.168.1.26 vincenzo-hpnotebook
   192.168.1.26 pi.hole
-rw-r--r-- 1 root root 238 giu 18 19:10 /etc/pihole/logrotate
   /var/log/pihole.log {
   	su root syslog
   	daily
   	copytruncate
   	rotate 5
   	compress
   	delaycompress
   	notifempty
   	nomail
   /var/log/pihole-FTL.log {
   	su root syslog
   	weekly
   	copytruncate
   	rotate 3
   	compress
   	delaycompress
   	notifempty
   	nomail
-rw-r--r-- 1 root root 1537 giu 21 20:07 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries
   local-ttl=2
   log-async
   dhcp-name-match=set:hostname-ignore,wpad
   dhcp-name-match=set:hostname-ignore,localhost
   dhcp-ignore-names=tag:hostname-ignore
   server=8.8.8.8
   server=8.8.4.4
   domain-needed
   bogus-priv
   interface=enp3s0
   server=/use-application-dns.net/
-rw-r--r-- 1 root root 638 giu 21 20:04 /etc/dnsmasq.d/02-pihole-dhcp.conf
   dhcp-authoritative
   dhcp-range=192.168.1.201,192.168.1.251,24h
   dhcp-option=option:router,192.168.1.1
   dhcp-leasefile=/etc/pihole/dhcp.leases
   domain=lan
   dhcp-rapid-commit
   dhcp-option=option6:dns-server,[::]
   dhcp-range=::100,::1ff,constructor:enp3s0,ra-names,slaac,24h
   ra-param=*,0,0
-rw-r--r-- 1 root root 3499 giu 18 19:10 /etc/lighttpd/lighttpd.conf
   server.modules = (
   	"mod_access",
   	"mod_accesslog",
   	"mod_auth",
   	"mod_expire",
   	"mod_compress",
   	"mod_redirect",
   	"mod_setenv",
   	"mod_rewrite"
   server.error-handler-404    = "/pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   mimetype.assign   = ( ".png"  => "image/png",
                         ".jpg"  => "image/jpeg",
                         ".jpeg" => "image/jpeg",
                         ".html" => "text/html",
                         ".js" => "application/javascript",
                         ".json" => "application/json",
                         ".txt"  => "text/plain",
                         ".svg"  => "image/svg+xml" )
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1704 giu 18 19:10 /etc/cron.d/pihole
   13 3   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   40 14  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 4312 giu 21 20:24 /var/log/lighttpd/error.log
   2020-06-21 00:00:11: (server.c.1785) logfiles cycled UID = 0 PID = 43796
   2020-06-21 16:18:56: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:02:26: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:02:35: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 687
   2020-06-21 20:02:37: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  SQLite3Stmt::execute(): Unable to execute statement: UNIQUE constraint failed: adlist.address in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 687
   2020-06-21 20:03:50: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:03:53: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:04:11: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:06:39: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:07:45: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  fopen(/etc/pihole/custom.list): failed to open stream: No such file or directory in /var/www/html/admin/scripts/pi-hole/php/customdns.php on line 33
   2020-06-21 20:07:46: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:07:52: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Trying to access array offset on value of type null in /var/www/html/admin/settings.php on line 23
   2020-06-21 20:08:35: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  fopen(/etc/pihole/custom.list): failed to open stream: No such file or directory in /var/www/html/admin/scripts/pi-hole/php/customdns.php on line 33
   2020-06-21 20:24:13: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Undefined offset: 0 in /var/www/html/pihole/index.php on line 205
   2020-06-21 20:24:13: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 206
   2020-06-21 20:24:14: (mod_fastcgi.c.421) FastCGI-stderr: PHP Notice:  Undefined offset: 0 in /var/www/html/pihole/index.php on line 205
   2020-06-21 20:24:14: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning:  array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 206
-rw-r--r-- 1 pihole pihole 11107 giu 21 20:14 /var/log/pihole-FTL.log
   [2020-06-21 03:14:52.647 10326] Reloading DNS cache
   [2020-06-21 03:14:52.648 10326] Blocking status is enabled
   [2020-06-21 03:14:52.649 10326] SQLite3 message: file unlinked while open: /etc/pihole/gravity.db (28)
   [2020-06-21 03:14:52.754 10326] INFO: No regex blacklist entries found
   [2020-06-21 03:14:52.754 10326] INFO: No regex whitelist entries found
   [2020-06-21 03:14:52.756 10326] Compiled 0 whitelist and 0 blacklist regex filters in 2.3 msec
   [2020-06-21 07:53:14.879 10326] Resizing "/FTL-strings" from 77824 to 81920
   [2020-06-21 08:25:21.922 10326] Resizing "/FTL-queries" from 786432 to 1048576
   [2020-06-21 14:51:01.804 10326] Resizing "/FTL-queries" from 1048576 to 1310720
   [2020-06-21 16:21:14.784 10326] Reloading DNS cache
   [2020-06-21 16:21:14.784 10326] Blocking status is enabled
   [2020-06-21 16:21:14.786 10326] SQLite3 message: file unlinked while open: /etc/pihole/gravity.db (28)
   [2020-06-21 16:21:14.920 10326] INFO: No regex blacklist entries found
   [2020-06-21 16:21:14.920 10326] INFO: No regex whitelist entries found
   [2020-06-21 16:21:14.922 10326] Compiled 0 whitelist and 0 blacklist regex filters in 2.3 msec
   [2020-06-21 16:28:30.483 10326] Received: Real-time signal 0 (34 -> 0)
   [2020-06-21 16:28:30.597 10326] INFO: No regex blacklist entries found
   [2020-06-21 16:28:30.598 10326] INFO: No regex whitelist entries found
   [2020-06-21 16:28:30.599 10326] Compiled 0 whitelist and 0 blacklist regex filters in 2.3 msec
   [2020-06-21 18:02:09.676 10326] Received: Real-time signal 0 (34 -> 0)
   [2020-06-21 18:02:09.792 10326] INFO: No regex blacklist entries found
   [2020-06-21 18:02:09.792 10326] INFO: No regex whitelist entries found
   [2020-06-21 18:02:09.794 10326] Compiled 0 whitelist and 0 blacklist regex filters in 2.4 msec
   [2020-06-21 18:02:16.531 10326] Received: Real-time signal 0 (34 -> 0)
   [2020-06-21 18:02:16.644 10326] INFO: No regex blacklist entries found
   [2020-06-21 18:02:16.644 10326] INFO: No regex whitelist entries found
   [2020-06-21 18:02:16.646 10326] Compiled 0 whitelist and 0 blacklist regex filters in 2.8 msec
   [2020-06-21 19:39:11.749 10326] Resizing "/FTL-dns-cache" from 61440 to 65536
   [2020-06-21 19:51:39.734 10326] Resizing "/FTL-queries" from 1310720 to 1572864
   [2020-06-21 20:02:43.931 10326] Received: Real-time signal 0 (34 -> 0)
   [2020-06-21 20:02:44.049 10326] INFO: No regex blacklist entries found
   [2020-06-21 20:02:44.049 10326] INFO: No regex whitelist entries found
   [2020-06-21 20:02:44.051 10326] Compiled 0 whitelist and 0 blacklist regex filters in 2.6 msec
   [2020-06-21 20:04:11.454 10326] Shutting down...
   [2020-06-21 20:04:11.456 10326] Finished final database update
   [2020-06-21 20:07:04.150 57167]    PORTFILE: Using /var/run/pihole-FTL.port
   [2020-06-21 20:07:04.150 57167]    SOCKETFILE: Using /var/run/pihole/FTL.sock
   [2020-06-21 20:07:04.150 57167]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
   [2020-06-21 20:07:04.150 57167]    MACVENDORDB: Using /etc/pihole/macvendor.db
   [2020-06-21 20:07:04.150 57167]    GRAVITYDB: Using /etc/pihole/gravity.db
   [2020-06-21 20:07:04.150 57167]    PARSE_ARP_CACHE: Active
   [2020-06-21 20:07:04.150 57167]    CNAME_DEEP_INSPECT: Active
   [2020-06-21 20:07:04.150 57167]    DELAY_STARTUP: No delay requested.
   [2020-06-21 20:07:04.150 57167]    BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
   [2020-06-21 20:07:04.150 57167] Finished config file parsing
   [2020-06-21 20:07:04.152 57167] Database version is 5
   [2020-06-21 20:07:04.152 57167] Database successfully initialized
   [2020-06-21 20:07:04.152 57167] Imported 0 queries from the long-term database
   [2020-06-21 20:07:04.152 57167]  -> Total DNS queries: 0
   [2020-06-21 20:07:04.152 57167]  -> Cached DNS queries: 0
   [2020-06-21 20:07:04.152 57167]  -> Forwarded DNS queries: 0
   [2020-06-21 20:07:04.152 57167]  -> Blocked DNS queries: 0
   [2020-06-21 20:07:04.152 57167]  -> Unknown DNS queries: 0
   [2020-06-21 20:07:04.152 57167]  -> Unique domains: 0
   [2020-06-21 20:07:04.152 57167]  -> Unique clients: 0
   [2020-06-21 20:07:04.152 57167]  -> Known forward destinations: 0
   [2020-06-21 20:07:04.152 57167] Successfully accessed setupVars.conf
   [2020-06-21 20:07:04.158 57169] PID of FTL process: 57169
   [2020-06-21 20:07:04.158 57169] Listening on port 4711 for incoming IPv4 telnet connections
   [2020-06-21 20:07:04.158 57169] Listening on port 4711 for incoming IPv6 telnet connections
   [2020-06-21 20:07:04.158 57169] Listening on Unix socket
   [2020-06-21 20:07:04.159 57169] Reloading DNS cache
   [2020-06-21 20:07:04.159 57169] Blocking status is enabled
   [2020-06-21 20:07:04.161 57169] INFO: No regex blacklist entries found
   [2020-06-21 20:07:04.163 57169] INFO: No regex whitelist entries found
   [2020-06-21 20:07:04.165 57169] Compiled 0 whitelist and 0 blacklist regex filters in 4.1 msec
   [2020-06-21 20:07:04.882 57169] New upstream server: 8.8.4.4 (0/128)
   [2020-06-21 20:09:53.533 57169] New upstream server: 8.8.8.8 (1/128)
   [2020-06-21 20:10:40.937 57169] Resizing "/FTL-strings" from 4096 to 8192
   [2020-06-21 20:14:48.268 57169] Resizing "/FTL-dns-cache" from 4096 to 8192
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 20480 giu 21 20:07 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 124 giu 21 20:07 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 8192 giu 21 20:14 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 98304 giu 21 20:10 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 48 giu 21 20:07 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 12288 giu 21 20:07 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4096 giu 21 20:07 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 262144 giu 21 20:07 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 giu 21 20:07 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 8192 giu 21 20:10 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 4096 giu 21 20:07 /dev/shm/FTL-upstreams
*** [ DIAGNOSING ]: Locale
    LANG=it_IT.UTF-8
-rw-r--r-- 1 pihole pihole 4067100 giu 21 20:24 /var/log/pihole.log
   -----head of pihole.log------
   Jun 21 00:00:04 dnsmasq[10326]: query[A] mobile.pipe.aria.microsoft.com from 192.168.1.225
   Jun 21 00:00:04 dnsmasq[10326]: gravity blocked mobile.pipe.aria.microsoft.com is 0.0.0.0
   Jun 21 00:00:46 dnsmasq[10326]: query[A] windows.kite.com from 192.168.1.225
   Jun 21 00:00:46 dnsmasq[10326]: forwarded windows.kite.com to 8.8.8.8
   Jun 21 00:00:46 dnsmasq[10326]: forwarded windows.kite.com to 8.8.4.4
   Jun 21 00:00:46 dnsmasq[10326]: reply windows.kite.com is 52.9.182.49
   Jun 21 00:01:35 dnsmasq[10326]: query[A] safebrowsing.googleapis.com from 192.168.1.225
   Jun 21 00:01:35 dnsmasq[10326]: forwarded safebrowsing.googleapis.com to 8.8.8.8
   Jun 21 00:01:35 dnsmasq[10326]: forwarded safebrowsing.googleapis.com to 8.8.4.4
   Jun 21 00:01:35 dnsmasq[10326]: reply safebrowsing.googleapis.com is 172.217.21.74
   Jun 21 00:01:51 dnsmasq[10326]: query[A] settings-win.data.microsoft.com from 192.168.1.225
   Jun 21 00:01:51 dnsmasq[10326]: forwarded settings-win.data.microsoft.com to 8.8.8.8
   Jun 21 00:01:51 dnsmasq[10326]: forwarded settings-win.data.microsoft.com to 8.8.4.4
   Jun 21 00:01:51 dnsmasq[10326]: reply settings-win.data.microsoft.com is <CNAME>
[✓] ** FINISHED DEBUGGING! **
    * For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
    * If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
    * Log will NOT be uploaded to tricorder.
Can you set the DNS settings on the modem's web interface. Is the modem in bridge mode?
As you can see in the network overview, the modem hasn't send any query to pihole yet (that is why it is red). This might be due to two reasons: it is not using pihole as DNS server or (also likely) it has not requested a sigle DNS resolution yet at all. It might be only doing so when refreshing NTP servers from time to time or looking for web firmware upgrades.
since it's not possible to set the dns server on the modem i configured pihole as dhcp server
To elaborate a bit on yubiuser's answer:
It is common for routers or modems to use the DNS server as assigned to them by your ISP. Thus, it would be normal for those class of devices to never appear as a client in Pi-hole (as long as they are indeed providing your connection to the Internet).
ok, thank you for the explanation, i think i got the point.
but anyway is there a way to let the modem 'ask' protection from pihole? in this way i get the protection also on the router linked to the principal modem.
another option could be to assign to pihole the ethernet door from which starts the cable that links the modem to the router, but i dont' know if it's possible.
or do you think it could be better to install a pihole on the secoundary router?
If you can't set the DNS server on the modem there is no way (I can think of) how to force the modem to use Pihole.
(And I think you have a misinterpretation of "protect" - pihole isn't really protecting the device from anything but it is protecting you from devices making queries to servers you might not want them to contact.)
I think I need a schema drawing from your network topology....
In case you are worried about your router/modem exposing sensitive data by (publically) contacting third parties (e.g. its manufacturers), you should probably consider to buy another router altogether (and yes, there are routers out there that perform data acquisition on behalf of their manufacturers, with or without asking for your consent explicitly).
If your router supports it, you could consider to use custom OSS firmware that would allow you to exercise that kind of control (and also is much less likely to monetise your data in the first place).
Who is saying that the modem needs DNS at all? If is just a plain simple cable modem, it will only do PPPoE and does not need to be able to resolve any domains at all.
