Missing dashboard widget?
Is the dashboard missing a widget?
Debug Token: https://tricorder.pi-hole.net/f9jujylarr
Looks like Show blocked domain entries is unticked.
Check the *Query Log *section under Settings | API/Web interface.
Thanks.
It seems that show permitted domains was unticked.
In any case, that did the trick where I have that area filled with reports. Thank you.
