Missing adlist when gravity updates
Hi. Running Pi-hole on a raspberry pi. When I run pihole -g I get the following error from malwaredomains.com;
[i] Received 60887 domains
[i] Target: https://mirror1.malwaredomains.com/files/justdomains
[✗] Status: Not found
[✗] List download failed: no cached list available
My debug token is: https://tricorder.pi-hole.net/zda8x93edt
Any idea why if this affects how pi-hole runs? Or if I need to be worried about it?
Thanks!
Chris
The malwaredomains list was removed from the default lists quite awhile ago due to it being deprecated. The default list now contains only the StephenBlack hosts llist. You can safely remove malwaredomains from your blocklists.
