mise a jour de Gravity impossible
bonjour,
j’ai installer pi-hole avec debian12 grâce à un tuto mais lorsque je veux mettre a jour gravity jai des erreur qui s’affiche a chaque DNS :slight_smile:
 [✓] DNS resolution is available
  [✓] Creating new gravity databases
  [i] Using libz compression
  [✗] Status: Connection Refused
  [✗] List download failed: no cached list available
j’ai chercher sur le net mais aucune soluce est-ce que quelqu’un pourrait m’aider?
merci d’avance
The site may have been unavailable at the time you updated gravity.
Try updating gravity again.
If it still doesn’t work, can you open the following URL in a browser?
Thank you jfb for your feedback, Indeed that must have been the problem! This morning everything is working perfectly!! :star_struck: thank you again :ok_hand:
