So, as of this writing, my FTL version is 5.23
network
table has an extra column at the end: alias client_id
(referencing the aliasclient
table's IDs). I'm gonna write down all the steps, for anyone else in future, who might stumble upon this issue, and wanna figure a way around it.
Load up the pihole-FTL database
sudo pihole-FTL sqlite3 /etc/pihole/pihole-FTL.db
Now, you can run .tables command, and it should return you the following,
For our solution, we are gonna focus on two tables, namely network
and aliasclient
. To see the content of network
table, we are gonna use the following command,
.mode column
.headers ON
SELECT * FROM network;
This, for example, gave me client details on my Pi-Hole network, as follows,
A device, say an iphone, has been assigned 10.66.66.62
IPv4 and fd42:42:42::62
IPv6 address on a VPN network (in my case Wireguard). @DL6ER pointed out that since this iphone is connected to VPN network with only IPv4 and IPv6 assignment, it's been given a mock-MAC
by FTL, which in case is ip-10.66.66.62
and ip-fd42:42:42::62
So, what we gotta do is assign each of these devices i.e. iphone with mock-MACK
address ip-10.66.66.62
a common identifier, which will reside in the column aliasclient_id
Before we can even give a common value aliasclient_id
for ip-10.66.66.62
, we need to first declare it in the table aliasclient
. So, in my case, I'll be choosing value 0
as aliasclient_id
. This would be declared in aliasclient
table as follows,
INSERT INTO aliasclient (id,name,comment) VALUES (0,'iphone',NULL);
Now that I've declared 0
as aliasclient_id
for my device iphone
, I'm gonna use it in the network table,
UPDATE network SET aliasclient_id = 0 WHERE hwaddr = 'ip-10.66.66.62';
UPDATE network SET aliasclient_id = 0 WHERE hwaddr = 'ip-fd42:42:42::62';
This is from the Pi-hole dashboard,
So, why does it still have two entries for device/client iphone
Well, you wanna ask FTL to import the new aliasclient(s),
sudo pkill -RTMIN+3 pihole-FTL
And now, the dashboard looks like this,
You need to repeat this every ever pair of IPv4 and IPv6 mock-MAC
assigned for a given device/client in your network
table (ensuring that the aliasclient_id
is declared in aliasclient
table).
