Manually changing dns settings after initial setup
Im new to the forum and grateful for the project.
I would like to know how to manually go back and change the dns servers that I setup
to use with Pi-hole [ as per the initial graphical setup process ].
I mistakenly selected custom instead of dns.watch and now want to change this.
Which file do I edit to do this?
Many thanks for your time.
You have a couple of options, easiest is through the web interface.. Settings page, DNS tab.
The other option is to run pihole -r from the command line and choose "reconfigure"
Thanks for your response, that worked perfectly.
