Lost password now logged out how to reset or retrieve? [Solved]
I am trying to use PuTTY to ssh in into the Pi-hole terminal and also try to login to admin portal via the web browser interface.
So far, no luck with the password I thought I have created during setup.
Unfortunately it seems that Pi-hole has a different idea what my password should be.
Any idea how to reset or retrieve the password from my Windows computer?
By the way , this is the guide I followed and I think I screwed up somewhere regarding the password part
https://blog.cryptoaustralia.org.au/2018/08/06/instructions-for-setting-up-pi-hole/
Thanks a million.
By default your Login should be pi and the password should be raspberry
if that doesnt get you in then your best bet may be to start over as i have no idea what you might have changed it to
if you are talking about password for the web interface that can be set using the following command pihole -a -p newpassword where you replace newpassword with what you would like to use
Thanks for the reply.
Here is where I went wrong and I hope others can learn from my mistakes.
After running
pi@raspberrypi:~ $ sudo raspi-config
I changed the user password from raspberry to newpassword
I also changed the hostname from
pi@raspberrypi:~ $
to
pi@somethingelse:~ $
..........When I try to log in via SSH or via the web browser, I used:
login as: somethingelse
password: newpassword
..........Big mistake. As the correct login credentials should be
login as: pi
..........In other words , I confused hostname with username (i.e. "login as")
..........One important point to remember is when you are still logged in by ssh to your RPi , you should go to your web portal in your browser and try to log in using the credentials you think you have , at
http://yourRPiipaddress/admin
If you cannot log in , then run this command to change to a password that works:
$ pihole -a -p Your_New_Password
Do not exit SSH until you have confirmed you can log into the Pi-hole admin portal in a browser.
