Lost connection to api
Hi everyone, my setup was working fine until I migrated, here is the docker-compose:
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      - "53:53/udp"
      - "53:53/tcp"
    environment:
      TZ: 'Europe/Lisbon'
      DNS1: unbound#53
      DNS2: "no"
      VIRTUAL_HOST: "DOMAIN HERE"
    cap_add:
        - NET_ADMIN
    networks:
        - proxy-network
    volumes:
      - '/home/aikoo7/.docker/pihole/etc/pihole:/etc/pihole'
      - '/home/aikoo7/.docker/pihole/etc/dnsmasq.d:/etc/dnsmasq.d'
    restart: unless-stopped
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.pihole.rule=Host(`pihole.aikoo7.duckdns.org`)"
      - "traefik.http.routers.pihole.entrypoints=websecure"
      - "traefik.http.services.pihole.loadbalancer.server.port=80"
  unbound:
    image: mvance/unbound-rpi:latest
    container_name: unbound
    networks:
      - proxy-network
    volumes:
      - /home/aikoo7/.docker/unbound/:/opt/unbound/etc/unbound/
networks:
  proxy-network:
    external: true
My token: https://tricorder.pi-hole.net/LNNbKUXn/
NOTE: The following token comes from a stock installation for easier debugging.
This message usually appears if Pi-hole is not running.
It also shows up if you left the browser window opened for a long time and the session expires.
Does it shows if you reload the page or try to login again?
This debug log doesn't show any issues with Pi-hole.
Hey,
I fixed it by enabling CONFIG_ANDROID_PARANOID_NETWORK in my kernel and recompiling.
Thanks for your help :slight_smile:
