I logged in to the Web UI and saw "Lost Connection to API". I restarted the pihole-FTL service and checked the Web UI again, to no avail. I then ran pihole -r to repair the subsystems. After running the repair script, I expected to see stats in the Web UI. pihole status shows that DNS is not running.
The Web UI continues to show "Lost Connection to API".
The output of this command should look something like this:
Active: **active (exited)** since Fri 2020-08-07 09:17:46 CDT; 3 days ago
Process: 11556 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Aug 07 09:17:45 Pi-3B-DEV systemd[1]: Starting LSB: pihole-FTL daemon...
Aug 07 09:17:46 Pi-3B-DEV pihole-FTL[11556]: Not running
Aug 07 09:17:46 Pi-3B-DEV su[11580]: **(to pihole) root on none**
Aug 07 09:17:46 Pi-3B-DEV su[11580]: pam_unix(su:session): session opened for user pihole by (uid=0)
Aug 07 09:17:46 Pi-3B-DEV pihole-FTL[11556]: FTL started!
Aug 07 09:17:46 Pi-3B-DEV su[11580]: pam_unix(su:session): session closed for user pihole
Aug 07 09:17:46 Pi-3B-DEV systemd[1]: Started LSB: pihole-FTL daemon.
I see a script in /etc/init.d that includes the following status function, which corresponds with what I'm seeing:
# Indicate the service status
status() {
if is_running; then
echo "[ ok ] pihole-FTL is running"
exit 0
else
echo "[ ] pihole-FTL is not running"
exit 1
fi
