Today have working normal, don't did any update and it stop working only see the message: "Lost connection to API"
12xesw00di
Thanks
jfb
2
You may be having the Cloudflare crash problem that others are reporting. From your debug log:
DNSSEC=true
PIHOLE_DNS_1=127.0.0.1#53
Thanks, I have disabled Cloudflare DNSSec and now working fine.
I'll check if have a workaround to fix this issue and continue using DNSSec.
system
Closed
4
