Log into PiHole Web UI and be able to manage the PiHole
login page is always shown no matters if password is right or wrong. changed many passwords even without special characters to exclude keyboard layout (i.e. aaaaaa). the only way i can login is without password.
Filesystem is not full.
Pi-hole [v5.11.4]
FTL [v5.16.1]
Web Interface [v5.13]
php 7.4.30
I suppose (but not sure) it started just after an apt-get upgrade
https://tricorder.pi-hole.net/ne1axJfO/
jfb
July 21, 2022, 10:45pm
2
Perhaps unrelated to this problem, but noted in your debug log - your DHCP server is not distributing the IP of Pi-hole as DNS server.
dns-server: 192.168.0.2
dns-server: 88.149.128.12
dns-server: 88.149.128.22
Your Pi-hole is active at this IP:
IPV4_ADDRESS=192.168.0.115/24
PIHOLE_INTERFACE=eth0
Thanks,
This sounds weird since:
pi@raspberrypi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.2 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::46e6:9a7f:8c93:4f21 prefixlen 64 scopeid 0x20
ether b8:27:eb:77:02:0b txqueuelen 1000 (Ethernet)
RX packets 28490 bytes 2658474 (2.5 MiB)
TX packets 27170 bytes 2554419 (2.4 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 528 bytes 56261 (54.9 KiB)
TX packets 528 bytes 56261 (54.9 KiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.252.201.1 netmask 255.255.255.0 destination 10.252.201.1
inet6 fe80::2840:c1a0:7aa4:7541 prefixlen 64 scopeid 0x20
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 500 (UNSPEC)
RX packets 101 bytes 18817 (18.3 KiB)
TX packets 168 bytes 37594 (36.7 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.109 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::c0c1:2415:76db:a3d1 prefixlen 64 scopeid 0x20
ether b8:27:eb:22:57:5e txqueuelen 1000 (Ethernet)
RX packets 325 bytes 77656 (75.8 KiB)
TX packets 79 bytes 35093 (34.2 KiB)
need anyway to go deep into this.
by the way, as you say, should not be related.
jfb
July 22, 2022, 5:41am
4
Run pihole -r
and select reconfigure to get Pi-hole configured for the active interface and IP.
Did you try different browsers? Do you use any browser plugins?
It was related
Reconfiguring fixed login issue
Thanks man!
system
Closed
August 12, 2022, 6:11am
7
