Long Tem Load message in the error log
LXC container - Happens on both current v5 and v6.
Is there an option to not do/hide this check or to limit the check to the LXC?
Thank you,
Thank you,
To disable this check:
in v5, add CHECK_LOAD=false to your /etc/pihole/pihole-FTL.conf.
in v6, find the [misc.check] section in /etc/pihole/pihole.toml and set load=false or use the web interface to change the value in Settings > All settings to disable misc.check.load:
Thank you for the help.
