When opening the long term data links in the admin console, I expect to see some entries
I receive an error that data could not be retrieved, and there was an error connecting to the database.
4xf1huithq
jfb
March 28, 2019, 6:49pm
2
What is the output of these commands from the Pi-Hole host terminal:
ls -lh /etc/pihole/pihole-FTL.db
cat /etc/pihole/pihole-FTL.conf
Thanks for the quick response.
the first command gives:
-rw-------. 1 pihole pihole 2.6M Mar 28 18:56 /etc/pihole/pihole-FTL.db
The second one returns:
PRIVACYLEVEL=0
jfb
March 28, 2019, 7:48pm
4
The permissions on the pihole database should be: -rw-r--r-- 1 pihole pihole
sudo chmod 644 /etc/pihole/pihole-FTL.db
sudo service pihole-FTL restart
That seems to have fixed it thanks. I am now seeing things like 0% where it just used to be blank, so it seems better, I think I just need to give it a bit more time to populate.
Not sure how this got set wrong as I just followed the install instructions, but there you go.
system
Closed
April 18, 2019, 7:57pm
6
