Being able to access long term data from webui.
When checking long term data I get the following error:
An unknown error occurred while loading the data.
Check the server's log files (/var/log/lighttpd/error-pihole.log) for details.
You may need to increase PHP memory limit.
/var/log/lighttpd/error-pihole.log has the following entries:
2023-12-11 19:55:02: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: Undefined array key "auth" in /var/www/html/admin/scripts/pi-hole/php/password.php on line 108
2023-12-11 19:56:40: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: Undefined array key "auth" in /var/www/html/admin/scripts/pi-hole/php/password.php on line 108
2023-12-11 19:58:47: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: Undefined array key "auth" in /var/www/html/admin/scripts/pi-hole/php/password.php on line 108
2023-12-12 13:12:14: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::prepare(): Unable to prepare statement: 1, no such table: query_storage in /var/www/html/admin/api_db.php on line 94
2023-12-12 13:12:14: (mod_fastcgi.c.451) FastCGI-stderr:PHP Fatal error: Uncaught Error: Call to a member function bindValue() on bool in /var/www/html/admin/api_db.php:95
2023-12-12 13:12:14: (mod_fastcgi.c.451) FastCGI-stderr:Stack trace:
2023-12-12 13:12:14: (mod_fastcgi.c.451) FastCGI-stderr:#0 {main}
2023-12-12 13:12:14: (mod_fastcgi.c.451) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 95
2023-12-12 13:12:22: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::prepare(): Unable to prepare statement: 1, no such table: query_storage in /var/www/html/admin/api_db.php on line 94
2023-12-12 13:12:22: (mod_fastcgi.c.451) FastCGI-stderr:PHP Fatal error: Uncaught Error: Call to a member function bindValue() on bool in /var/www/html/admin/api_db.php:95
2023-12-12 13:12:22: (mod_fastcgi.c.451) FastCGI-stderr:Stack trace:
2023-12-12 13:12:22: (mod_fastcgi.c.451) FastCGI-stderr:#0 {main}
2023-12-12 13:12:22: (mod_fastcgi.c.451) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 95
2023-12-12 13:14:27: (server.c.2057) server stopped by UID = 0 PID = 1
2023-12-12 13:14:28: (server.c.1551) server started (lighttpd/1.4.63)
2023-12-12 13:14:32: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::prepare(): Unable to prepare statement: 1, no such table: query_storage in /var/www/html/admin/api_db.php on line 94
2023-12-12 13:14:32: (mod_fastcgi.c.451) FastCGI-stderr:PHP Fatal error: Uncaught Error: Call to a member function bindValue() on bool in /var/www/html/admin/api_db.php:95
2023-12-12 13:14:32: (mod_fastcgi.c.451) FastCGI-stderr:Stack trace:
2023-12-12 13:14:32: (mod_fastcgi.c.451) FastCGI-stderr:#0 {main}
2023-12-12 13:14:32: (mod_fastcgi.c.451) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 95
2023-12-12 13:15:25: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::prepare(): Unable to prepare statement: 1, no such table: query_storage in /var/www/html/admin/api_db.php on line 94
2023-12-12 13:15:25: (mod_fastcgi.c.451) FastCGI-stderr:PHP Fatal error: Uncaught Error: Call to a member function bindValue() on bool in /var/www/html/admin/api_db.php:95
2023-12-12 13:15:25: (mod_fastcgi.c.451) FastCGI-stderr:Stack trace:
2023-12-12 13:15:25: (mod_fastcgi.c.451) FastCGI-stderr:#0 {main}
2023-12-12 13:15:25: (mod_fastcgi.c.451) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 95
2023-12-12 14:07:15: (server.c.2057) server stopped by UID = 0 PID = 1
2023-12-12 14:07:16: (server.c.1551) server started (lighttpd/1.4.63)
2023-12-12 14:07:30: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::prepare(): Unable to prepare statement: 1, no such table: query_storage in /var/www/html/admin/api_db.php on line 94
2023-12-12 14:07:30: (mod_fastcgi.c.451) FastCGI-stderr:PHP Fatal error: Uncaught Error: Call to a member function bindValue() on bool in /var/www/html/admin/api_db.php:95
2023-12-12 14:07:30: (mod_fastcgi.c.451) FastCGI-stderr:Stack trace:
2023-12-12 14:07:30: (mod_fastcgi.c.451) FastCGI-stderr:#0 {main}
2023-12-12 14:07:30: (mod_fastcgi.c.451) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 95
2023-12-12 14:31:13: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::prepare(): Unable to prepare statement: 1, no such table: query_storage in /var/www/html/admin/api_db.php on line 94
2023-12-12 14:31:13: (mod_fastcgi.c.451) FastCGI-stderr:PHP Fatal error: Uncaught Error: Call to a member function bindValue() on bool in /var/www/html/admin/api_db.php:95
2023-12-12 14:31:13: (mod_fastcgi.c.451) FastCGI-stderr:Stack trace:
2023-12-12 14:31:13: (mod_fastcgi.c.451) FastCGI-stderr:#0 {main}
2023-12-12 14:31:13: (mod_fastcgi.c.451) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 95
I followed the FAQ at FAQ - Pi-hole documentation, but unfortunately the problem persists
https://tricorder.pi-hole.net/buqtnvjG/
Any suggestion is appreciated! Thank you!
