Folks, After an SD card problem reinstalled Pi-Hole, the system seems to be working except Flush Logs does not clear the logs, dashboard still lists all the data, try again still no clear. The info windown suggests however that it has been successful.
If I use pihole -f I get the following error;
Blockquote pihole -f
sed: can't read /etc/pihole/pihole-FTL.conf: No such file or directory
[i] Flushing /var/log/pihole.log .../opt/pihole/piholeLogFlush.sh: line 56: sqlite3: command not found
[✓] Flushed /var/log/pihole.log
[✓] Deleted queries from database
