I have a problem with local DNS records on my Pi-hole. It will resolve a configured DNS record only if I directly use the Pi-hole as the DNS server for my machine but NOT if I use DNS resolution via my router.
My setup is the following
- Pi-Hole v5.1.2 with IP
192.168.178.52 - Fritz!Box with IP
192.168.178.1 - MacBook with IP
192.168.178.38
Configuration
- the Pi-hole has a local DNS record
localregistryconfigured which points to my MacBook - the Router is configured to use the Pi-hole as the DNS server
- the MacBook has no explicit DNS server set and hence uses the Fritz!Box for DNS resolution which in turn uses Pi-Hole
- I know the setup works b/c the Pi-hole dashboard shows the correct DNS requests from my router in the logs/dashboard
If I now try to resolve localregistry from my MacBook, I get the following unexpected response
$ dig localregistry
; <<>> DiG 9.10.6 <<>> localregistry
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14557
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;localregistry. IN A
;; Query time: 14 msec
;; SERVER: 192.168.178.1#53(192.168.178.1)
;; WHEN: Tue Oct 20 16:28:58 CEST 2020
;; MSG SIZE rcvd: 31
However, if I set the DNS server of my MacBook to my Pi-hole and do the lookup again, I receive the expected result:
$ dig localregistry
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 52019
localregistry. 2 IN A 192.168.178.38
;; Query time: 12 msec
;; SERVER: 192.168.178.52#53(192.168.178.52)
;; WHEN: Tue Oct 20 16:31:34 CEST 2020
;; MSG SIZE rcvd: 58
