Local DNS not resolving in browsers
  • Operating System (Family and Version) - Unraid 6.12.4
  • Hardware - Docker - pihole/pihole:latest
  • Docker compose file or Docker run command
  -d
  --name='pihole'
  --net='bond0'
  --ip='10.0.0.3'
  -e TZ="America/Los_Angeles"
  -e HOST_OS="Unraid"
  -e HOST_HOSTNAME="Tower"
  -e HOST_CONTAINERNAME="pihole"
  -e 'TCP_PORT_53'='53'
  -e 'UDP_PORT_53'='53'
  -e 'UDP_PORT_67'='67'
  -e 'TCP_PORT_80'='80'
  -e 'TCP_PORT_443'='443'
  -e 'PIHOLE_DNS_'='1.1.1.1;1.0.0.1'
  -e 'TZ'='America/Los_Angeles'
  -e 'WEBPASSWORD'='L3opards.'
  -e 'INTERFACE'='br0'
  -e 'ServerIP'='10.0.0.1'
  -e 'ServerIPv6'=''
  -e 'IPv6'='False'
  -e 'DNSMASQ_LISTENING'='all'
  -e 'WEBUIBOXEDLAYOUT'='boxed'
  -e 'DNSMASQ_USER'='root'
  -l net.unraid.docker.managed=dockerman
  -l net.unraid.docker.webui='http://[IP]:[PORT:80]/admin'
  -l net.unraid.docker.icon='https://i.imgur.com/OWkNcEn.png'
  -v '/mnt/user/appdata/pihole/pihole/':'/etc/pihole/':'rw'
  -v '/mnt/user/appdata/pihole/dnsmasq.d/':'/etc/dnsmasq.d/':'rw'
  --cap-add=NET_ADMIN
  --restart=unless-stopped 'pihole/pihole:latest'
7a8daefd39bddbe3c5549de881e13a4b63624d631abc7205574b84237f94660a
The command finished successfully!
When I try and access sonarr-anime.mydomain.com which is setup in Local DNS it gives me a blank page on a browser. However dig with and without pointing to the pihole shows that it is correct there:
dig @10.0.0.3 sonarr-anime.mydomain.com
; <<>> DiG 9.10.6 <<>> @10.0.0.3 sonarr-anime.mydomain.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 15887
;sonarr-anime.mydomain.com.	IN	A
sonarr-anime.mydomain.com. 0	IN	A	10.0.0.144
;; Query time: 1 msec
;; SERVER: 10.0.0.3#53(10.0.0.3)
;; WHEN: Thu Apr 24 10:28:57 PDT 2025
;; MSG SIZE  rcvd: 70
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2025-04-24:10:35:07 debug log has been initialized.
[i] System has been running for 27 days, 23 hours, 23 minutes
[✓] Version: v6.0.6
[i] Remotes: origin     https://github.com/pi-hole/pi-hole.git (fetch)
             origin     https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v6.0.6-0-g0f7803b
[✓] Version: v6.1
[i] Remotes: origin     https://github.com/pi-hole/web.git (fetch)
             origin     https://github.com/pi-hole/web.git (push)
[i] Branch: master
[i] Commit: v6.1-0-g1eaddca
[✓] Version: v6.1
[i] Branch: master
[i] Commit: a3313229
[i] Pi-hole Docker Container: 2025.04.0
[✓] Distro:  Alpine
[✓] Version: 3.19.7
[✓] dig return code: 0
[i] dig response: "Raspbian=11,12 Ubuntu=20,22,23,24 Debian=11,12 Fedora=40,41 CentOS=9,10"
[✓] Distro and version supported
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[✓] Firewalld service not detected
*** [ DIAGNOSING ]: System hardware configuration
[i] Not enough permissions inside Docker container (skipped)
*** [ DIAGNOSING ]: Processor details
*** [ DIAGNOSING ]: Disk usage
   overlay         100G   39G   62G  39% /
   tmpfs            64M     0   64M   0% /dev
   shm              64M   11M   54M  17% /dev/shm
   shfs            1.4T  330M  1.4T   1% /etc/pihole
   /dev/loop2      100G   39G   62G  39% /etc/hosts
   tmpfs            63G     0   63G   0% /proc/acpi
   tmpfs            63G     0   63G   0% /sys/firmware
*** [ DIAGNOSING ]: Network interfaces and addresses
   1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
       inet6 ::1/128 scope host
   2: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN qlen 1000
       link/ipip 0.0.0.0 brd 0.0.0.0
   381: eth0@if9: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP
       link/ether 02:42:0a:00:00:03 brd ff:ff:ff:ff:ff:ff
       inet 10.0.0.3/22 brd 10.0.3.255 scope global eth0
       inet6 2001:5a8:60e4:7c00:42:aff:fe00:3/64 scope global dynamic flags 100
          valid_lft 17341sec preferred_lft 17341sec
       inet6 2001:5a8:60e4:7c00::b/64 scope global flags 02
       inet6 fe80::42:aff:fe00:3/64 scope link
*** [ DIAGNOSING ]: Network routing table
   default via 10.0.0.1 dev eth0
   10.0.0.0/22 dev eth0 scope link  src 10.0.0.3
[i] Default IPv4 gateway(s):
     10.0.0.1%eth0
   * Pinging first gateway 10.0.0.1...
[✓] Gateway responded.
[i] Default IPv6 gateway(s):
     2001:5a8:60e4:7c00::1%eth0
     fe80::76ac:b9ff:fe50:7b8d%eth0
   * Pinging first gateway 2001:5a8:60e4:7c00::1...
[✓] www.ogloszenia-ukrainek.pl is NOERROR on lo (127.0.0.1)
[✓] www.ogloszenia-ukrainek.pl is NOERROR on eth0 (10.0.0.3)
[✓] doubleclick.com is 142.250.189.174 via a remote, public DNS server (8.8.8.8)
[✓] van.ads.link4ads.com is NOERROR on lo (::1)
[✓] van.ads.link4ads.com is NOERROR on eth0 (2001:5a8:60e4:7c00:42:aff:fe00:3)
[✓] van.ads.link4ads.com is NOERROR on eth0 (2001:5a8:60e4:7c00::b)
[✓] van.ads.link4ads.com is NOERROR on eth0 (fe80::42:aff:fe00:3%eth0)
[✓] doubleclick.com is 2607:f8b0:4005:80d::200e via a remote, public DNS server (2001:4860:4860::8888)
*** [ DIAGNOSING ]: Discovering active DHCP servers (takes 6 seconds)
   Timeout: 6 seconds
   * Received 88 bytes from fe80::76ac:b9ff:fe50:7b8d @ eth0
     Hop limit: 64
     Stateful address conf.: No
     Stateful other conf.: No
     Mobile home agent: No
     Router preference: High
     Neighbor discovery proxy: No
     Router lifetime: 1800 s
     Reachable time: N/A
     Retransmit time: N/A
     - Prefix: 2001:5a8:60e4:7c00::/64
       Valid lifetime: 17341 sec
       Preferred lifetime: 17341 sec
       On-link: Yes
       Autonomous address conf.: Yes
     MTU: 1500 bytes (valid)
     Source link-layer address: 74:AC:B9:50:7B:8D
     Recursive DNS server 1/1: 2001:5a8:60e4:7c00::1
     DNS server lifetime:17341 sec
   * Received 40 bytes from fe80::c98:775f:48fb:aaea @ eth0
     Hop limit: undefined
     Router preference: Medium
     Router lifetime: 0 s
     Reachable time: N/A
     - Route: fd89:eb:eeae::/64
       Route preference: Medium
       Route lifetime: 1800 sec
     Source link-layer address: C0:95:6D:4F:6D:8E
   * Received 310 bytes from 10.0.0.1 @ eth0
     Offered IP address: 10.0.2.103
     Server IP address: 10.0.0.1
     Relay-agent IP address: N/A
     BOOTP server: (empty)
     BOOTP file: (empty)
     DHCP options:
      Message type: DHCPOFFER (2)
      server-identifier: 10.0.0.1
      lease-time: 86400 ( 1d )
      renewal-time: 43200 ( 12h )
      rebinding-time: 75600 ( 21h )
      netmask: 255.255.252.0
      domain-name: "mydomain.com"
      broadcast: 10.0.3.255
      dns-server: 10.0.0.3
      dns-server: 10.0.0.4
      router: 10.0.0.1
      --- end of options ---
     Reachable time: N/A
   Received 1 DHCP (IPv4) and 3 RA (IPv6) answers on eth0
[i] systemctl/service not installed inside docker container (skipped)
*** [ DIAGNOSING ]: Pi-hole-FTL full status
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-r----- 1 pihole pihole 660M Apr 24 10:32 /etc/pihole/pihole-FTL.db
*** [ DIAGNOSING ]: Gravity Database
-rw-r----- 1 pihole pihole 8.4M Apr 20 03:24 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
   property              value
   version               19
   gravity_restored      false
   updated               1745144641
   gravity_count         143685
   Last gravity run finished at: Sun Apr 20 03:24:01 PDT 2025
   ----- First 10 Gravity Domains -----
   localhost.localdomain
   0.0.0.0
   ad-assets.futurecdn.net
   ck.getcookiestxt.com
   eu1.clevertap-prod.com
   wizhumpgyros.com
   coccyxwickimp.com
   webmail-who-int.000webhostapp.com
   010sec.com
   01mspmd5yalky8.com
*** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0           1  Default                                             2023-05-19 09:48:15  2023-05-19 09:48:15  The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
   id     enabled  group_ids     address        date_added           date_modified        comment
   1            1  0             https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts                                      2023-05-19 09:48:15  2023-05-19 09:48:15  Migrated from /etc/pihole/adlists.list
-rw-r----- 1 pihole pihole 5.6K Apr  4 09:27 /etc/pihole/dnsmasq.conf
   hostsdir=/etc/pihole/hosts
   no-resolv
   port=53
   server=1.1.1.1
   server=1.0.0.1
   server=2606:4700:4700::1111
   server=2606:4700:4700::1001
   cache-size=10000
   localise-queries
   log-queries
   log-async
   log-facility=/var/log/pihole/pihole.log
   bogus-priv
   use-stale-cache=3600
   except-interface=nonexisting
   domain=lan
   local=/lan/
   local=/pi.hole/
   host-record=pi.hole,0.0.0.0
   cname=vw.mydomain.com,vaultwarden.mydomain.com
   server=/test/
   server=/localhost/
   server=/invalid/
   server=/bind/
   server=/onion/
   cache-rr=ANY
   filter-rr=ANY
-rw-r----- 1 root root 421 Apr 24 10:32 /etc/pihole/logrotate
   /var/log/pihole/pihole.log {
       daily
       copytruncate
       rotate 5
       compress
       delaycompress
       notifempty
       nomail
   /var/log/pihole/FTL.log {
       weekly
       copytruncate
       rotate 3
       compress
       delaycompress
       notifempty
       nomail
   /var/log/pihole/webserver.log {
       weekly
       copytruncate
       rotate 3
       compress
       delaycompress
       notifempty
       nomail
-rw-r----- 1 pihole pihole 56K Apr  4 09:27 /etc/pihole/pihole.toml
   [dns]
     upstreams = [
       "1.1.1.1",
       "1.0.0.1",
       "2606:4700:4700::1111",
       "2606:4700:4700::1001"
     ] ### CHANGED, default = []
     CNAMEdeepInspect = true
     blockESNI = true
     EDNS0ECS = true
     ignoreLocalhost = false
     showDNSSEC = true
     analyzeOnlyAandAAAA = false
     piholePTR = "PI.HOLE"
     replyWhenBusy = "ALLOW"
     blockTTL = 2
     hosts = [
       "10.0.0.152 books.mydomain.com",
       "10.0.20.61 frigate.mydomain.com",
       "10.0.0.141 jellyfin.mydomain.com",
       "10.0.0.145 radarr-anime.mydomain.com",
       "10.0.0.143 radarr-movies.mydomain.com",
       "10.0.0.144 sonarr-anime.mydomain.com",
       "10.0.0.142 sonarr-tv.mydomain.com",
       "10.0.0.103 vaultwarden.mydomain.com"
     domainNeeded = false
     expandHosts = false
     domain = "lan"
     bogusPriv = true
     dnssec = false
     interface = "br0" ### CHANGED, default = ""
     hostRecord = ""
     listeningMode = "ALL" ### CHANGED, default = "LOCAL"
     queryLogging = true
     cnameRecords = [
       "vw.mydomain.com,vaultwarden.mydomain.com"
     port = 53
     revServers = []
     [dns.cache]
       size = 10000
       optimizer = 3600
       upstreamBlockedTTL = 86400
     [dns.blocking]
       active = true
       mode = "NULL"
       edns = "TEXT"
     [dns.specialDomains]
       mozillaCanary = true
       iCloudPrivateRelay = true
       designatedResolver = true
       [dns.reply.host]
         force4 = true ### CHANGED, default = false
         IPv4 = "10.0.0.1" ### CHANGED, default = ""
         force6 = false
         IPv6 = ""
       [dns.reply.blocking]
         force4 = false
         IPv4 = ""
         force6 = false
         IPv6 = ""
     [dns.rateLimit]
       count = 1000
       interval = 60
   [dhcp]
     active = false
     start = ""
     end = ""
     router = ""
     netmask = ""
     leaseTime = ""
     ipv6 = false
     rapidCommit = false
     multiDNS = false
     logging = false
     ignoreUnknownClients = false
     hosts = []
     [ntp.ipv4]
       active = true
       address = ""
     [ntp.ipv6]
       active = true
       address = ""
     [ntp.sync]
       active = true
       server = "pool.ntp.org"
       interval = 3600
       count = 8
       [ntp.sync.rtc]
         set = false
         device = ""
         utc = true
   [resolver]
     resolveIPv4 = true
     resolveIPv6 = true
     networkNames = true
     refreshNames = "IPV4_ONLY"
   [database]
     DBimport = true
     maxDBdays = 91
     DBinterval = 60
     useWAL = true
     [database.network]
       parseARPcache = true
       expire = 91
   [webserver]
     domain = "pi.hole"
     acl = ""
     port = "80o,443os" ### CHANGED, default = "80o,443os,[::]:80o,[::]:443os"
     threads = 50
     headers = [
       "Content-Security-Policy: default-src 'self' 'unsafe-inline';",
       "X-Frame-Options: DENY",
       "X-XSS-Protection: 0",
       "X-Content-Type-Options: nosniff",
       "Referrer-Policy: strict-origin-when-cross-origin"
     ] ### CHANGED, default = [ "X-DNS-Prefetch-Control: off", "Content-Security-Policy: default-src 'self' 'unsafe-inline';", "X-Frame-Options: DENY", "X-XSS-Protection: 0", "X-Content-Type-Options: nosniff", "Referrer-Policy: strict-origin-when-cross-origin" ]
     serve_all = false
     [webserver.session]
       timeout = 1800
       restore = true
     [webserver.tls]
       cert = "/etc/pihole/tls.pem"
     [webserver.paths]
       webroot = "/var/www/html"
       webhome = "/admin/"
       prefix = ""
     [webserver.interface]
       boxed = true
       theme = "default-auto"
     [webserver.api]
       max_sessions = 16
       prettyJSON = false
       pwhash = "$BALLOON-SHA256$v=1$s=1024,t=32$KMwz92hg+XjPLzZ2ET/t5A==$2wEGsEELCAu3IxV+i+JW6K9noznKfObmF3BaU45LQnU=" ### CHANGED, default = ""
       totp_secret = ""
       app_pwhash = ""
       app_sudo = false
       cli_pw = true
       excludeClients = []
       excludeDomains = []
       maxHistory = 86400
       maxClients = 10
       client_history_global_max = true
       allow_destructive = true
       [webserver.api.temp]
         limit = 60.000000
         unit = "C"
   [files]
     pid = "/run/pihole-FTL.pid"
     database = "/etc/pihole/pihole-FTL.db"
     gravity = "/etc/pihole/gravity.db"
     gravity_tmp = "/tmp"
     macvendor = "/macvendor.db" ### CHANGED, default = "/etc/pihole/macvendor.db"
     setupVars = "/etc/pihole/setupVars.conf"
     pcap = ""
     [files.log]
       ftl = "/var/log/pihole/FTL.log"
       dnsmasq = "/var/log/pihole/pihole.log"
       webserver = "/var/log/pihole/webserver.log"
   [misc]
     privacylevel = 0
     delay_startup = 0
     nice = -10
     addr2line = true
     etc_dnsmasq_d = false
     dnsmasq_lines = []
     extraLogging = false
     readOnly = false
     [misc.check]
       load = true
       shmem = 90
       disk = 90
   [debug]
     database = false
     networking = false
     locks = false
     queries = false
     flags = false
     shmem = false
     gc = false
     arp = false
     regex = false
     api = false
     tls = false
     overtime = false
     status = false
     caps = false
     dnssec = false
     vectors = false
     resolver = false
     edns0 = false
     clients = false
     aliasclients = false
     events = false
     helper = false
     config = false
     inotify = false
     webserver = false
     extra = false
     reserved = false
     ntp = false
     netlink = false
     all = false
-rw-r--r-- 1 pihole pihole 372 Apr 24 10:32 /etc/pihole/versions
   CORE_VERSION=v6.0.6
   CORE_BRANCH=master
   CORE_HASH=0f7803b7
   GITHUB_CORE_VERSION=v6.0.6
   GITHUB_CORE_HASH=0f7803b7
   WEB_VERSION=v6.1
   WEB_BRANCH=master
   WEB_HASH=1eaddca8
   GITHUB_WEB_VERSION=v6.1
   GITHUB_WEB_HASH=1eaddca8
   FTL_VERSION=v6.1
   FTL_BRANCH=master
   FTL_HASH=a3313229
   GITHUB_FTL_VERSION=v6.1
   GITHUB_FTL_HASH=a3313229
   DOCKER_VERSION=2025.04.0
   GITHUB_DOCKER_VERSION=2025.04.0
/etc/cron.d does not exist.
*** [ DIAGNOSING ]: contents of /var/log/pihole
-rw-r----- 1 pihole pihole 4.7K Apr 24 10:32 /var/log/pihole/FTL.log
   -----head of FTL.log------
   2025-04-04 17:53:09.870 UTC [1M] INFO: Config file /etc/pihole/pihole.toml not available (r): No such file or directory
   2025-04-24 10:32:10.528 PDT [53M] INFO: ########## FTL started on 7a8daefd39bd! ##########
   2025-04-24 10:32:10.528 PDT [53M] INFO: FTL branch: master
   2025-04-24 10:32:10.528 PDT [53M] INFO: FTL version: v6.1
   2025-04-24 10:32:10.528 PDT [53M] INFO: FTL commit: a3313229
   2025-04-24 10:32:10.528 PDT [53M] INFO: FTL date: 2025-03-30 17:53:24 +0100
   2025-04-24 10:32:10.528 PDT [53M] INFO: FTL user: root
   2025-04-24 10:32:10.528 PDT [53M] INFO: Compiled for linux/amd64 (compiled on CI) using cc (Alpine 14.2.0) 14.2.0
   2025-04-24 10:32:10.533 PDT [53M] INFO: Wrote config file:
   2025-04-24 10:32:10.533 PDT [53M] INFO:  - 156 total entries
   2025-04-24 10:32:10.533 PDT [53M] INFO:  - 145 entries are default
   2025-04-24 10:32:10.533 PDT [53M] INFO:  - 11 entries are modified
   2025-04-24 10:32:10.533 PDT [53M] INFO:  - 0 entries are forced through environment
   2025-04-24 10:32:10.536 PDT [53M] INFO: Parsed config file /etc/pihole/pihole.toml successfully
   2025-04-24 10:32:10.536 PDT [53M] INFO: PID file does not exist or not readable
   2025-04-24 10:32:10.536 PDT [53M] INFO: No other running FTL process found.
   2025-04-24 10:32:10.536 PDT [53M] WARNING: Insufficient permissions to set process priority to -10 (CAP_SYS_NICE required), process priority remains at 0
   2025-04-24 10:32:10.537 PDT [53M] WARNING: Starting pihole-FTL as user root is not recommended
   2025-04-24 10:32:10.537 PDT [53M] INFO: PID of FTL process: 53
   2025-04-24 10:32:10.538 PDT [53M] INFO: listening on 0.0.0.0 port 53
   2025-04-24 10:32:10.538 PDT [53M] INFO: listening on :: port 53
   2025-04-24 10:32:10.538 PDT [53M] INFO: PID of FTL process: 53
   2025-04-24 10:32:10.557 PDT [53M] INFO: Database version is 21
   2025-04-24 10:32:10.557 PDT [53M] INFO: Database successfully initialized
   2025-04-24 10:32:12.662 PDT [53M] INFO: Imported 121518 queries from the on-disk database (it has 10861011 rows)
   2025-04-24 10:32:12.662 PDT [53M] INFO: Parsing queries in database
   2025-04-24 10:32:12.715 PDT [53M] INFO:   10000 queries parsed...
   2025-04-24 10:32:12.734 PDT [53M] INFO:   20000 queries parsed...
   2025-04-24 10:32:12.749 PDT [53M] INFO:   30000 queries parsed...
   2025-04-24 10:32:12.767 PDT [53M] INFO:   40000 queries parsed...
   2025-04-24 10:32:12.782 PDT [53M] INFO:   50000 queries parsed...
   2025-04-24 10:32:12.795 PDT [53M] INFO:   60000 queries parsed...
   2025-04-24 10:32:12.809 PDT [53M] INFO:   70000 queries parsed...
   2025-04-24 10:32:12.823 PDT [53M] INFO:   80000 queries parsed...
   2025-04-24 10:32:12.849 PDT [53M] INFO:   90000 queries parsed...
   -----tail of FTL.log------
   2025-04-24 10:32:12.863 PDT [53M] INFO:   100000 queries parsed...
   2025-04-24 10:32:12.878 PDT [53M] INFO:   110000 queries parsed...
   2025-04-24 10:32:12.890 PDT [53M] INFO:   120000 queries parsed...
   2025-04-24 10:32:12.892 PDT [53M] INFO: Imported 121516 queries from the long-term database
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Total DNS queries: 121516
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Cached DNS queries: 98736
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Forwarded DNS queries: 10286
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Blocked DNS queries: 10912
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Unknown DNS queries: 0
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Unique domains: 1293
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Unique clients: 67
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> DNS cache records: 300
   2025-04-24 10:32:12.892 PDT [53M] INFO:  -> Known forward destinations: 4
   2025-04-24 10:32:12.917 PDT [53M] WARNING: Insufficient permissions to set system time (CAP_SYS_TIME required), NTP client not available
   2025-04-24 10:32:12.917 PDT [53/T83] INFO: NTP server listening on 0.0.0.0:123 (IPv4)
   2025-04-24 10:32:12.917 PDT [53/T84] INFO: NTP server listening on :::123 (IPv6)
   2025-04-24 10:32:12.917 PDT [53M] INFO: FTL is running as root
   2025-04-24 10:32:12.918 PDT [53M] INFO: Reading certificate from /etc/pihole/tls.pem ...
   2025-04-24 10:32:12.918 PDT [53M] INFO: Using SSL/TLS certificate file /etc/pihole/tls.pem
   2025-04-24 10:32:12.918 PDT [53M] INFO: Web server ports:
   2025-04-24 10:32:12.918 PDT [53M] INFO:   - 0.0.0.0:80 (HTTP, IPv4, optional, OK)
   2025-04-24 10:32:12.918 PDT [53M] INFO:   - 0.0.0.0:443 (HTTPS, IPv4, optional, OK)
   2025-04-24 10:32:12.918 PDT [53M] INFO: Restored 1 API session from the database
   2025-04-24 10:32:12.919 PDT [53M] INFO: Blocking status is enabled
   2025-04-24 10:32:13.024 PDT [53/T85] INFO: Compiled 0 allow and 0 deny regex for 67 clients in 0.2 msec
-rw-r----- 1 pihole pihole 79 Apr 24 10:32 /var/log/pihole/webserver.log
   -----head of webserver.log------
   [2025-04-24 10:32:12.917 PDT 53] Initializing HTTP server on ports "80o,443os"
   -----tail of webserver.log------
*** [ DIAGNOSING ]: contents of /dev/shm
total 11M
-rw------- 1 root root 340K Apr 24 10:32 FTL-53-clients
-rw------- 1 root root 4.0K Apr 24 10:32 FTL-53-clients-lookup
-rw------- 1 root root  328 Apr 24 10:32 FTL-53-counters
-rw------- 1 root root  20K Apr 24 10:32 FTL-53-dns-cache
-rw------- 1 root root 4.0K Apr 24 10:32 FTL-53-dns-cache-lookup
-rw------- 1 root root  44K Apr 24 10:32 FTL-53-domains
-rw------- 1 root root  12K Apr 24 10:32 FTL-53-domains-lookup
-rw------- 1 root root 556K Apr 24 10:32 FTL-53-fifo-log
-rw------- 1 root root   88 Apr 24 10:32 FTL-53-lock
-rw------- 1 root root 8.0K Apr 24 10:32 FTL-53-overTime
-rw------- 1 root root 4.0K Apr 24 10:32 FTL-53-per-client-regex
-rw------- 1 root root 8.5M Apr 24 10:35 FTL-53-queries
-rw------- 1 root root 768K Apr 24 10:32 FTL-53-recycler
-rw------- 1 root root  144 Apr 24 10:32 FTL-53-settings
-rw------- 1 root root  80K Apr 24 10:32 FTL-53-strings
-rw------- 1 root root  28K Apr 24 10:32 FTL-53-upstreams
-rw-r--r-- 1 root root 71 Apr 24 10:32 /etc/resolv.conf
   nameserver 127.0.0.11
   nameserver 2001:5a8:60e4:7c00::1
   options ndots:0
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
/opt/pihole/piholeDebug.sh: line 546: locale: command not found
-rw-r----- 1 pihole pihole 58K Apr 24 10:35 /var/log/pihole/pihole.log
   -----head of pihole.log------
   Apr 24 10:32:12 dnsmasq[53]: started, version pi-hole-v2.91 cachesize 10000
   Apr 24 10:32:12 dnsmasq[53]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN2 DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth DNSSEC loop-detect inotify dumpfile
   Apr 24 10:32:12 dnsmasq[53]: using nameserver 1.1.1.1#53
   Apr 24 10:32:12 dnsmasq[53]: using nameserver 1.0.0.1#53
   Apr 24 10:32:12 dnsmasq[53]: using nameserver 2606:4700:4700::1111#53
   Apr 24 10:32:12 dnsmasq[53]: using nameserver 2606:4700:4700::1001#53
   Apr 24 10:32:12 dnsmasq[53]: using only locally-known addresses for onion
   Apr 24 10:32:12 dnsmasq[53]: using only locally-known addresses for bind
   Apr 24 10:32:12 dnsmasq[53]: using only locally-known addresses for invalid
   Apr 24 10:32:12 dnsmasq[53]: using only locally-known addresses for localhost
   Apr 24 10:32:12 dnsmasq[53]: using only locally-known addresses for test
   Apr 24 10:32:12 dnsmasq[53]: using only locally-known addresses for pi.hole
   Apr 24 10:32:12 dnsmasq[53]: using only locally-known addresses for lan
   Apr 24 10:32:12 dnsmasq[53]: read /etc/hosts - 10 names
   Apr 24 10:32:12 dnsmasq[53]: read /etc/pihole/hosts/custom.list - 8 names
   Apr 24 10:32:12 dnsmasq[53]: query[AAAA] api.github.com from 10.0.0.3
   Apr 24 10:32:12 dnsmasq[53]: forwarded api.github.com to 1.1.1.1
   Apr 24 10:32:12 dnsmasq[53]: forwarded api.github.com to 1.0.0.1
   Apr 24 10:32:12 dnsmasq[53]: forwarded api.github.com to 2606:4700:4700::1111
   Apr 24 10:32:12 dnsmasq[53]: forwarded api.github.com to 2606:4700:4700::1001
   -----tail of pihole.log------
   Apr 24 10:35:08 dnsmasq[53]: query[A] mobile-collector.newrelic.com from 10.0.3.98
   Apr 24 10:35:08 dnsmasq[53]: gravity blocked mobile-collector.newrelic.com is 0.0.0.0
   Apr 24 10:35:09 dnsmasq[53]: query[A] ups19.localdomain from 10.0.0.41
   Apr 24 10:35:09 dnsmasq[53]: cached ups19.localdomain is NXDOMAIN
   Apr 24 10:35:09 dnsmasq[53]: query[A] ups19.localdomain.mydomain.com from 10.0.0.41
   Apr 24 10:35:09 dnsmasq[53]: cached ups19.localdomain.mydomain.com is 104.21.61.76
   Apr 24 10:35:09 dnsmasq[53]: cached ups19.localdomain.mydomain.com is 172.67.207.97
   Apr 24 10:35:09 dnsmasq[53]: query[A] ups218.localdomain from 10.0.0.41
   Apr 24 10:35:09 dnsmasq[53]: cached ups218.localdomain is NXDOMAIN
   Apr 24 10:35:09 dnsmasq[53]: query[A] ups218.localdomain.mydomain.com from 10.0.0.41
   Apr 24 10:35:09 dnsmasq[53]: cached ups218.localdomain.mydomain.com is 104.21.61.76
   Apr 24 10:35:09 dnsmasq[53]: cached ups218.localdomain.mydomain.com is 172.67.207.97
   Apr 24 10:35:10 dnsmasq[53]: query[A] pi.hole from 127.0.0.1
   Apr 24 10:35:10 dnsmasq[53]: Pi-hole hostname pi.hole is 10.0.0.1
   Apr 24 10:35:13 dnsmasq[53]: query[PTR] 54.3.0.10.in-addr.arpa from 10.0.0.41
   Apr 24 10:35:13 dnsmasq[53]: config 10.0.3.54 is NXDOMAIN
   Apr 24 10:35:14 dnsmasq[53]: query[A] api.zinc.dev from 10.0.0.101
   Apr 24 10:35:14 dnsmasq[53]: cached api.zinc.dev is NODATA-IPv4
   Apr 24 10:35:14 dnsmasq[53]: query[AAAA] api.zinc.dev from 10.0.0.101
   Apr 24 10:35:14 dnsmasq[53]: cached api.zinc.dev is NODATA-IPv6
[✓] ** FINISHED DEBUGGING! **
