LinkedIn is blocked
I can go to www.linkedin.com
DNS resolution fails
Just wondering what sites need to be whitelisted/not blacklisted for LinkedIn to work. Please note that linkedin.com is already whitelisted. Thanks.
Solved my own problem. I needed to whitelist www.linkedin.com, not just linkedin.com. Hope this helps someone.
@peic
For future reference, the following sites are called from the LinkedIn website:
'www.linkedin.com
static-exp1.licdn.com
platform.linkedin.com
sb.scorecardresearch.com
www.youtube.com
googleads.g.doubleclick.net
static.doubleclick.net
yt3.ggpht.com
i.ytimg.com
fonts.gstatic.com
You can easily find these by using the Adam:ONE Assistant Chrome extension for any website.
Thank you, though it seems to be working now with just www.linkedin.com on the whitelist.
