I have a problem with tp-link deco's, and limited gateway connections via guest network.
Setup: My I have a raspberry pi with Pihole als my DHCP.
My ziggo modem is in bridge. Also I have a TP-LINK Deco M4 mesh wifi setup, in AP mode. I work with switches in between .
On the TP-link DECO i run a main wifi network (2.4 / 5 GHz) and a guest network (2.4 GHz)
Because the deco is not the dhcp server, the guest network runs on the same IP range (not really a seperated lan).
On my guest network i have ca 20 devices connected , like smart plugs, IOT, but there seem te be a limit somehow. When I connect another device to the guest network, I don't have internet. (also devices that had no problems in the past)
I do get IP adres, mac , gateway etc.
I am connected in the deco app, but I don not have internet.(while other connected devices do have internet via the guest netwotk)
When connect the device to the main deco wifi network, I suddenly do have internet connection...
Could this be caused be a setting in the pihole DHCP? (like max gateway connections _),
Also I experience sometimes that my network (including wired network) is not responding anymore.
and the only fix is a reboot of pihole, with the tplink deco-master powered off. Like ithe deco's sometimes suddenly go back into router mode and wants to take over the network or somehing? I was not able to check that, because pihole IP is not reachable at that moment...
