browsing to http://ipaddress/admin should open the GUI for pihole
Page fails ot load
https://tricorder.pi-hole.net/ihIHs3FE/
My problem is very similar to:
except
I've been trying to install LetsEncrpyt using certbot to make the webpage HTTPS compliant.
For some reason lighttpd now fails to start, obviously I've screwed something up along the way ![]()
root@pi-hole:/# systemctl status lighttpd
ā lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2022-06-13 07:19:49 BST; 7min ago
Process: 25199 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Jun 13 07:19:49 pi-hole systemd[1]: lighttpd.service: Unit entered failed state.
Jun 13 07:19:49 pi-hole systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Jun 13 07:19:49 pi-hole systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Jun 13 07:19:49 pi-hole systemd[1]: Stopped Lighttpd Daemon.
Jun 13 07:19:49 pi-hole systemd[1]: lighttpd.service: Start request repeated too quickly.
Jun 13 07:19:49 pi-hole systemd[1]: Failed to start Lighttpd Daemon.
root@pi-hole:/# ls -al /etc/lighttpd/
total 36
drwxr-xr-x 4 root root 4096 Jun 13 07:22 .
drwxr-xr-x 121 root root 12288 Jun 10 09:46 ..
drwxr-xr-x 2 root root 4096 Sep 17 2018 conf-available
drwxr-xr-x 2 root root 4096 Sep 17 2018 conf-enabled
-rw-r--r-- 1 root root 730 Jun 10 15:01 external.conf
-rw-r--r-- 1 root root 3894 Jun 11 14:55 lighttpd.conf
-rw-r--r-- 1 root root 3664 Nov 3 2021 lighttpd.conf.orig
root@pi-hole:/# ls -al /var/log/lighttpd
total 2220
drwxr-x--- 2 www-data www-data 4096 Jun 12 06:25 .
drwxr-xr-x 8 root root 4096 Jun 13 07:25 ..
-rwxr-xr-x 1 www-data www-data 0 Jun 12 06:25 access.log
-rw-r--r-- 1 www-data www-data 2100978 Jun 11 14:53 access.log.1
-rw-r--r-- 1 www-data www-data 1190 Apr 11 06:25 access.log.10.gz
-rw-r--r-- 1 www-data www-data 435 Apr 3 06:25 access.log.11.gz
-rw-r--r-- 1 www-data www-data 1227 Mar 27 13:00 access.log.12.gz
-rw-r--r-- 1 www-data www-data 8358 Jun 6 03:28 access.log.2.gz
-rw-r--r-- 1 www-data www-data 1098 May 29 06:25 access.log.3.gz
-rw-r--r-- 1 www-data www-data 918 May 23 01:02 access.log.4.gz
-rw-r--r-- 1 www-data www-data 496 May 14 21:43 access.log.5.gz
-rw-r--r-- 1 www-data www-data 1398 May 9 06:25 access.log.6.gz
-rw-r--r-- 1 www-data www-data 547 May 1 01:55 access.log.7.gz
-rw-r--r-- 1 www-data www-data 1275 Apr 25 03:20 access.log.8.gz
-rw-r--r-- 1 www-data www-data 1213 Apr 17 06:25 access.log.9.gz
-rw-r--r-- 1 www-data www-data 0 Jun 12 06:25 error.log
-rw-r--r-- 1 www-data www-data 53464 Jun 11 14:53 error.log.1
-rw-r--r-- 1 www-data www-data 635 Apr 9 23:56 error.log.10.gz
-rw-r--r-- 1 www-data www-data 262 Mar 28 09:42 error.log.11.gz
-rw-r--r-- 1 www-data www-data 430 Mar 21 13:02 error.log.12.gz
-rw-r--r-- 1 www-data www-data 588 Jun 5 06:10 error.log.2.gz
-rw-r--r-- 1 www-data www-data 445 May 28 20:44 error.log.3.gz
-rw-r--r-- 1 www-data www-data 314 May 17 21:43 error.log.4.gz
-rw-r--r-- 1 www-data www-data 90 May 9 06:25 error.log.5.gz
-rw-r--r-- 1 www-data www-data 437 May 7 18:16 error.log.6.gz
-rw-r--r-- 1 www-data www-data 262 Apr 25 12:23 error.log.7.gz
-rw-r--r-- 1 www-data www-data 404 Apr 23 12:34 error.log.8.gz
-rw-r--r-- 1 www-data www-data 481 Apr 14 12:04 error.log.9.gz
My linux knowledge is very basic ![]()
