Is there an external custom port config that disables using port 80 that I am missing? I'm worried (not WORRIED worried) that this will be overwritten with updates.
You only need to use /etc/lighttpd/external.conf if you are using an old Pi-hole version (prior to v5.15) and you always kept updating this old version. That was the way Pi-hole used to configure lighttpd.
If you are on a fresh install (or your first installation was newer than v5.15, than you have the new config files. The current lighttpd config uses the original config file (developed by lighttpd - not the one Pi-hole modified) and also uses the /etc/lighttpd/conf-enabled directory.
Apparently you are using the current version.
This means:
/etc/lighttpd/external.conf is not used in this configuration;
you can add extra config files in /etc/lighttpd/conf-enabled directory;
you can change the port directly in /etc/lighttpd/lighttpd.conf or you can override the original port using another file (it's your choice).
Note about operators:
If you are setting the port in /etc/lighttpd/lighttpd.conf, you should use =
If you have a port already set and you want to override the port in another file, you should use :=
About IPv6:
The IPv6 port is set in /etc/lighttpd/lighttpd.conf (it uses the server.port value set on that file):
# default listening port for IPv6 falls back to the IPv4 port
include "/etc/lighttpd/conf-enabled/*.conf"
Every other config files are include only after that.
If you are overriding the port in another file, this won't change the IPv6 port.
Suggestions:
change the port directly in /etc/lighttpd/lighttpd.conf(this change will survive Pi-hole updates in newer versions) and remove the new file overriding the port.
Personally, I think this is the cleaner solution.
use your include file, but change the order of those lines to:
About IPv6:
OK this part explains my issue.
I'll just change it in the lighttpd.conf and hope I remember if/when it breaks
