Hi
I simply enabled the lighttpd status module which provides /server-status/ (for monitoring by observium). But I cannot reach this directory, it just triggers the 404 "Website blocked" msg. Any clues?
Thanks
Hi
Thanks
Have you tried going straight to the file that it should be loading (index.html
)? I don't think Pi-hole is affecting this issue, because the block page is just the 404 handler.
