Lighttpd does not start
Pi.hole or any IP of my Box should work and open.
Its just dont open... so its
1eyz942j3v
Did the installation finish correctly? I see e.g.
   Dec 28 16:24:48 dnsmasq[25428]: Fehler beim Laden der Namen von /etc/pihole/local.list: Datei oder Verzeichnis nicht gefunden
   Dec 28 16:24:48 dnsmasq[25428]: Fehler beim Laden der Namen von /etc/pihole/black.list: Datei oder Verzeichnis nicht gefunden
   Dec 28 16:24:48 dnsmasq[25428]: Fehler beim Laden der Namen von /etc/pihole/gravity.list: Datei oder Verzeichnis nicht gefunden
which indicates that the installation was not completed.
Yes, it did... i will reinstall pi-hole later and see what happends...
okay, while reinstalling, pihole-ftl did not install.... but there was not an errormessage for it, it just got ignored... i dont think that this is an inportant thing in this question but it happend... ._. and still while reinstalling lighttpd didnt start...
new code for "pihole -d" 8hj8cu34kp
According to your new debug log,
[āœ“] FTL: v2.13.1
pihole-FTL got installed correctly. What is it's status? (sudo service pihole-FTL status)
:~# service pihole-FTL status
ā— pihole-FTL.service - LSB: pihole-FTL daemon
Loaded: loaded (/etc/init.d/pihole-FTL; generated; vendor preset: enabled)
Active: inactive (dead)
//EDIT: I've started it now, with service pihole-FTL start now its running... so i think this is just a hick up.
:~# service lighttpd status
ā— lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2017-12-29 15:44:11 CET; 24h ago
Process: 24113 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=127)
Can you restart it? If no, does it give any error?
:~# service lighttpd start
Job for lighttpd.service failed because the control process exited with error code.
See "systemctl status lighttpd.service" and "journalctl -xe" for details.
:~# systemctl status lighttpd.service
Active: failed (Result: exit-code) since Sat 2017-12-30 16:29:52 CET; 23s ago
Process: 5070 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=127)
Dez 30 16:29:51 djcray-X751LD systemd[1]: Failed to start Lighttpd Daemon.
Dez 30 16:29:51 djcray-X751LD systemd[1]: lighttpd.service: Unit entered failed state.
Dez 30 16:29:51 djcray-X751LD systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Dez 30 16:29:52 djcray-X751LD systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Dez 30 16:29:52 djcray-X751LD systemd[1]: Stopped Lighttpd Daemon.
Dez 30 16:29:52 djcray-X751LD systemd[1]: lighttpd.service: Start request repeated too quickly.
Dez 30 16:29:52 djcray-X751LD systemd[1]: Failed to start Lighttpd Daemon.
Dez 30 16:29:52 djcray-X751LD systemd[1]: lighttpd.service: Unit entered failed state.
Dez 30 16:29:52 djcray-X751LD systemd[1]: lighttpd.service: Failed with result 'exit-code'.
How about that?
Maybe running lighttpd directly can reveal some more details as well, try
sudo service lighttpd stop
lighttpd -D -f /etc/lighttpd/lighttpd.conf
Dez 30 16:46:57 djcray-X751LD systemd-resolved[1387]: Using degraded feature set (UDP) for DNS server 127.0.1.1
lighttpd: symbol lookup error: lighttpd: undefined symbol: FAMNoExists
Looking at this bug report, one of the suggested workarounds is:
sudo apt-get install gamin
Did it allready, and now its working. idk why but its working now just fine.
No idea what gamin is or does but this fixed my problem. Many Thanks
Same. Install gamin worked.
I'm using lubuntu.
Many Thanks for the top.
