Pihole is running with errors. Lighted does not exist,Failed to resolve www.ai-financialanalyst.com on wlan0 ,/etc/lighttpd/conf.d does not exist..
_Many errors in the pi-hole debug log. Not sure what they mean or how to fix. Using Raspberry Pi 5 64-bit Debian.
Also in Pi-hole diagnosis getting Adlist with ID 12 was inaccessible during last gravity run. ads-api.tiktok.com
*** [ DIAGNOSING ]: contents of /etc/lighttpd/conf.d
That's a notification and not an error and can be ignored. Some supported platforms use a /conf.d directory to store configuration files. Your setup uses /conf-enabled for active configuration files as seen here:
That is not a URL for a list, that's a domain. If you want to block access to that domain then you need to add it as a domain and not a list. A list should be a URL that returns a list of domains to be blocked as you have with the other 11 lists you are using.
