Lighttp Pi hole for GUI address
i need change Gui addressf or my hole. I've found an aricle abput lighttp on this forum.
The problem is that i'm a newbie. Can you help? Thanks in advance...
Can you explain further what you are trying to accomplish?
i want to install Openvaultmedia without unistalling Pihole and Openvault isn't compatible with portainer
i mean something like that: Ability to change the GUI port
i'm a newbie. Can you help me?
