Hello everybody!
My first post here and feeling late to this game...
I've started using pi-hole - installed on a Raspberry pi - about a week ago. It seemed to work fine, except being bypassed by my android phone (galaxy S7), but it is a known fact.
Yesterday I had my first incident with the pi-hole (initially not even thinking of it being the cause): in the middle of a transaction with my bank (chrome browser), the connection with the bank's server was blocked. Subsequent attempts ended in impossible connection with the bank's website...
On a hunch, I started the Edge and attempted the same connection, and, to my surprise, all the connection and transaction worked flawlessly! Ok, I said, it seems to be the browser, although I never had any issue connecting to the bank with any browser, or OS!
Today I had another surprise: a lot of legit websites (reddit.com, aliexpress.com, ebay.com, etc.) stopped loading - on both Chrome and Edge.
A nslookup showed no blocking from pi-hole's part! Ping worked too. I did a bit (~3hours!) of research on the issue - by the way, even the discourse.pi-hole.net was blocked, how crazy is that?! The only thing that improved things was to reload the database (pihole -g). After that, things started to work, but only on Chrome, not on Edge, where a lot of sites wouldn't load.
I understand, it sounds like browser related issues, they are different and with different settings - and believe me, I went several times thru them - but only by 'Disabling Blocking' on the thing made them all disappear.
I thought / hopped this is something like 'set it and forget it' kind of thing, but if it goes on like this, it's becoming like a part-time job and I'm not sure it's worth the trouble.
And to make this already long post even longer, this is the log of such an aliexpress.com failed connection attempt:
Jul 2 11:41:14 dnsmasq[770]: reply aliexpress.com is 47.254.175.252
Jul 2 11:41:14 dnsmasq[770]: reply aliexpress.com is NODATA
Jul 2 11:41:14 dnsmasq[770]: query[A] www.aliexpress.com from 192.168.178.20
Jul 2 11:41:14 dnsmasq[770]: forwarded www.aliexpress.com to 8.8.8.8
Jul 2 11:41:14 dnsmasq[770]: query[HTTPS] www.aliexpress.com from 192.168.178.20
Jul 2 11:41:14 dnsmasq[770]: reply www.aliexpress.com is
Jul 2 11:41:14 dnsmasq[770]: reply www.aliexpress.com.gds.alibabadns.com is
Jul 2 11:41:14 dnsmasq[770]: reply global.aliexpress.com is
Jul 2 11:41:14 dnsmasq[770]: reply global.aliexpress.com.gds.alibabadns.com is
Jul 2 11:41:14 dnsmasq[770]: reply eu1111.alicdn.com.edgekey.net is blocked during CNAME inspection
Jul 2 11:41:14 dnsmasq[770]: gravity blocked www.aliexpress.com is NODATA
Jul 2 11:41:14 dnsmasq[770]: gravity blocked www.aliexpress.com is 0.0.0.0
Any help would be greatly appreciated and I thank you in advance for it!
Luka
