Hi guys!
I need help to fix my problem with Pi-Hole DNS settings on my second router (OpenWRT)
I have 2 routers connected together. OS is Ubuntu.
Main router is a FritzBox.
Second router is a WR2100 (OpenWRT)
My 'host machine' is using first router with Pi-Hole enabled and it's working great on the FritzBox router.
Enabled: 'dns-rebind-protection'
/etc/dnsmasq.d/01-pihole.conf
Setting on FritzBox router:
rebind-domain-ok=pi.hole
On both machines Pi-Hole DHCP is off.
My VM machine is using second router.
Both machines, only local.
On my 'VM machine' with enabled Pi-Hole, internet is only working, when on WAN section (second router) DNS 1.1.1.1 (example) is set.
Once I set WAN DNS (second router) to my 'Pi-Hole ip' which I have set in SetupVars.conf my name resolution does not work anymore.
"LAN TO WAN connection" is working when I set DNS setting at WAN section on my second router to example 1.1.1.1.
Then internet/name resolution is working.
On my second router 'dns-rebind-protection' is enabled.
Do I need 'dns-rebind-protection' on second router enabled?
My 'host machine' and my 'VM machine' have the same settings only the ips are set differently.
It must be the second router for dns settings I guess.
DNS-settings router Pi-Hole:
On my main router:
Internet DNS server is set to: Pi-Hole ip (ipv4) - Host machine
DHCP Local DNS server is set to: Pi-Hole ip (ipv4) - Host machine
On my second router:
WAN DNS server when set to: Pi-Hole ip (ipv4) - vm machine = internet/name resolution not working
DHCP Local DNS server is set to: Pi-Hole ip (ipv4) - vm machine = internet/name resolution not working
WAN DNS server when set to: 1.1.1.1 - vm machine = internet/name resolution is working
Does anyone know what I have to set under OpenWRT (dns) in the second router?
