Das spuckt er mir aus: So wie ich das sehe ist da ein Problem mit der install manpage wie kann ich das beheben?
pi@raspberrypi:~ $ pihole -r
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u1
[i] Repair option selected
[✓] Disk space check
[✓] Checking apt-get for upgraded packages... 3 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✓] Checking for apt-utils
[✓] Checking for dialog
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[✓] Checking for bc
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for resolvconf
[✓] Checking for lighttpd
[✓] Checking for php7.0-common
[✓] Checking for php7.0-cgi
[✓] Checking for php7.0-sqlite3
[✓] Enabling lighttpd service to start on reboot...
[✓] Installing scripts from /etc/.pihole
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[✓] Creating directory for blocking page, and copying files
[✗] Backing up index.lighttpd.html
[✓] Installing sudoer file
[✓] Installing latest Cron script
[✓] Installing latest logrotate script
[i] FTL Checks...
[✓] Detected ARM-hf architecture (armv6 or lower) Using ARM binary
[i] Latest FTL Binary already installed (v4.1.2). Confirming Checksum...
[i] Checksum correct. No need to download!
[✗] man page db not updated, man pages not installed
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[✓] Starting lighttpd service...
[i] Restarting services...
[✓] Enabling pihole-FTL service to start on reboot...
[✓] Starting pihole-FTL service...
[✓] Deleting existing list cache
[✗] DNS resolution is currently unavailable
[✓] DNS resolution is now available
[i] Target: raw.githubusercontent.com (hosts)
[i] Target: mirror1.malwaredomains.com (justdomains)
[i] Target: sysctl.org (hosts)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[i] Target: adaway.org (hosts.txt)
[i] Target: adblock.amroemischengutshof.de (youtube-ads-list.txt)
[✓] Consolidating blocklists
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 162677
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 138995
[i] Number of whitelisted domains: 10
[i] Number of blacklisted domains: 1
[i] Number of regex filters: 3
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] Force-reloading DNS service
[✓] DNS service is running
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v4.1.1
Current AdminLTE version is v4.1.1
Current FTL version is v4.1.2
