I am trying to block the ads on the ITV Hub player. From searching online I found that tom.itv.com if blocked stops the ads from running. However, this also breaks the player as it says that I am running an adblock software. Is there any other domain that can be blocked in order to get it to work ?
Thank you! I initially used tom.itv.com which blocked the ads perfectly, but I had a different issue to OP - somehow it breaks my player controls. The pause, fast forward and rewind buttons were all rendered inoperable, and the time stamp remained at 0 the entire time, so it was impossible to pause anything or even carry on watching from where you left off! I have no idea how DNS blocking could cause this, but I tested it and that's what happened. Switching to your reccomended domain has fixed the broken player while still blocking ads. Thanks again
