This (Solve DNS Resolution in Other Containers when using Docker pihole) works but container failed to automatically restart on raspberry pi restart with this error in journalctl -u docker
warning msg="Failed to allocate and map port 53-53: Error starting userland proxy: listen udp4 192.168.50.11:53: bind: cannot assign requested address"
docker-compose:
version: "3"
services:
pihole:
container_name: pihole
image: jacklul/pihole:latest
ports:
- "53:53/tcp"
- "192.168.50.11:53:53/udp"
- "67:67/udp"
- "8080:80/tcp"
environment:
TZ: 'Asia/Karachi'
ADMIN_EMAIL: email@gmail.com
WEBPASSWORD: 'pass'
WEBTHEME: 'default-dark'
PIHOLE_DNS_: '192.168.50.1'
FTLCONF_REPLY_ADDR4: '192.168.50.11'
FTLCONF_REPLY_ADDR6: 'fe80::cc5a:101f:64:9db6'
volumes:
- './etc-pihole/:/etc/pihole/'
- './etc-dnsmasq.d/:/etc/dnsmasq.d/'
- './etc-pihole-updatelists/:/etc/pihole-updatelists/'
#dns:
#- 192.168.50.1
#- 1.1.1.1
# Recommended but not required (DHCP needs NET_ADMIN)
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
# cap_add:
# - NET_ADMIN
restart: unless-stopped
Note that I can manually restart it using docker-compose up -d but this was automatically restarting without IP bind (before applying this solution) because restart is set to unless-stopped.
Reason of using IP bind:
This works but container failed to automatically restart on raspberry pi restart with this error in journalctl -u docker
docker-compose:
version: "3"
services:
pihole:
ports:
- "53:53/tcp"
- "67:67/udp"
- "8080:80/tcp"
environment:
TZ: 'Asia/Karachi'
WEBPASSWORD: 'pass'
volumes:
#dns:
#- 192.168.50.1
#- 1.1.1.1
# cap_add:
# - NET_ADMIN
This message shows the port 53 is already being used when Pi-hole container tries to restart.
When you restart your machine, there is something else binding to this port.
When docker starts, the port is already taken.
It could be a service on the host, or maybe another container starting before Pi-hole.
You need to find out which service is doing this.
You are not running the official Pi-hole Docker image.
If your issue persists, you should also consider contacting the maintainer of your specific image.
Issue also occurs with official pi image. This image has just some custom blocklists.
I am only running two containers. pihole and wireguard. both automatically starts on startup. As far as I know 53 port isn't used by anyone since I can manually start failed pihole using docker-compose up -d and it works without any issue.
Note that if I change "192.168.50.11:53:53/udp" to "53:53/udp" then it works as expected and restarts automatically on reboot. so this seems like a docker specific issue.
The message is telling port 53 is not available at restart.
There are 2 possibilities:
- there is something using port 53 during the restart (not very likely, since you said there is no other services);
- the network is still not fully available at the moment the container tries to restart. The port is not available and the warning is generated.
I cannot confirm this:
I am unable to recreate your observation with an official Pi-hole image.
Rebooting my RPi 3A will also bring up the Pi-hole container without a glitch.
It is not just adding some blocklists.
The docker file you've linked is utilising apt-get to install packages, and it then downloads an installation script that applies further alterations to the image, potentially establishing new or altered dependencies that a vanilla Pi-hole image doesn't have.
That said, I notice that your docker-compose only binds port 53 UDP to a specific address:
What is the reason for that?
I am able to successfully reboot my RPi even with those unusual bindings, but nevertheless:
Did you try to bind port 53 TCP to your 192.168.50.11 as well?
