Issues after updating to 4.1.1 - Dashboard and DNS resolution issues
I've updated this morning to the latest 4.1.1 and I am seeing lots of issues. Everything has been running fine before.
Please note that I am running Cloudflare DoH, is has been confirmed as per here and worked fine up until the upgrade:
Issues I am seeing:
  1. Status / reply missing in the dashboard fir clients, see the picture
  2. Unable to resolve correctly, ie:
pi@p1:~ $ cf
ERRO[0001] Update check failed                           error="Post https://update.equinox.io/check: dial tcp: lookup update.equinox.io on 127.0.0.1:53: server misbehaving"
pi@p1:~ $
pi@p1:~ $ sudo apt-get update
Err:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
  Temporary failure resolving 'raspbian.raspberrypi.org'
Err:2 http://archive.raspberrypi.org/debian stretch InRelease
  Temporary failure resolving 'archive.raspberrypi.org'
Reading package lists... Done
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/InRelease  Temporary failure resolving 'raspbian.raspberrypi.org'
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/stretch/InRelease  Temporary failure resolving 'archive.raspberrypi.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
pi@p1:~ $
    [✓] ** FINISHED DEBUGGING! **
    * For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
    * If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
I am unable to get one:
    * Using openssl for transmission.
[✗]  There was an error uploading your debug log.
   * A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
pi@p1:~ $ pihole -d
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2019-01-16:12:29:17 debug log has been initialized.
[i] Core: v4.1.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.1.1-0-g8d85d46
[i] Web: v4.1.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.1.1-0-gde7aa5a3
[✓] FTL: v4.1.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] 1.4.45
[i] 7.0.30
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
   10.1.1.2/24 matches the IP found in /etc/pihole/setupVars.conf
   fe80::4faa:21ca:4d08:5142 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 10.1.1.1
   * Pinging 10.1.1.1...
[✓] Gateway responded.
127.0.0.1:42081 cloudflare (IPv4)
127.0.0.1:54 cloudflare (IPv4)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[*:80] is in use by lighttpd
[*:53] is in use by pihole-FTL
[127.0.0.1:4711] is in use by pihole-FTL
[[::1]:4711] is in use by pihole-FTL
dig: '' is not a legal name (unexpected end of input)
[✗] Failed to resolve  via localhost (127.0.0.1)
[✗] Failed to resolve  via Pi-hole (10.1.1.2)
[✓] doubleclick.com is 216.58.206.78 via a remote, public DNS server (8.8.8.8)
[✗] Failed to resolve  via localhost (::1)
[✗] Failed to resolve  via Pi-hole (fd08:2e5:9779:1:b22a:43a0:672d:f6d7)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
[✓] lighttpd daemon is active
    TEMPERATUREUNIT=C
    WEBUIBOXEDLAYOUT=boxed
    PIHOLE_INTERFACE=eth0
    IPV4_ADDRESS=10.1.1.2/24
    IPV6_ADDRESS=fd08:2e5:9779:1:b22a:43a0:672d:f6d7
    PIHOLE_DNS_1=
    PIHOLE_DNS_2=
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=true
    BLOCKING_ENABLED=true
HTTP/1.1 200 OK
Date: Wed, 16 Jan 2019 12:29:23 GMT
Server: lighttpd/1.4.45
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 0 Jan 16 12:20 /etc/pihole/gravity.list
-rw-r--r-- 1 root root 381 Oct  8 18:47 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 0 Sep 30 21:31 /etc/pihole/blacklist.txt
-rw-r--r-- 1 root root 112 Jan 16 12:20 /etc/pihole/local.list
   10.1.1.2 p1
   fd08:2e5:9779:1:b22a:43a0:672d:f6d7 p1
   10.1.1.2 pi.hole
   fd08:2e5:9779:1:b22a:43a0:672d:f6d7 pi.hole
-rw-r--r-- 1 root root 234 Jan 16 12:13 /etc/pihole/logrotate
   /var/log/pihole.log {
   	su root root
   	daily
   	copytruncate
   	rotate 5
   	compress
   	delaycompress
   	notifempty
   	nomail
   /var/log/pihole-FTL.log {
   	su root root
   	weekly
   	copytruncate
   	rotate 3
   	compress
   	delaycompress
   	notifempty
   	nomail
-rw-r--r-- 1 root root 2027 Jan  8 22:05 /etc/pihole/whitelist.txt
   analytics.google.com
   analytics.twitter.com
   graph.facebook.com
   spclient.wg.spotify.com
   uk-london.privateinternetaccess.com
   ocsp.apple.com
   pictures.zooplus.com
   ssl.microsofttranslator.com
   mobile.pipe.aria.microsoft.com
   f-log-extension.grammarly.io
   settings-win.data.microsoft.com
   sls.update.microsoft.com
   client.wns.windows.com
   audio-fac.spotify.com
   metrics.icloud.com
   lcprd1.samsungcloudsolution.net
   osb.samsungqbe.com
   time.samsungcloudsolution.com
   cdn.samsungcloudsolution.com
   acr0.samsungcloudsolution.com
   referrer.disqus.com
   platform.linkedin.com
   c.disquscdn.com
   disqus.com
   instagram.com
   s.youtube.com
   sentry.io
   telemetry.malwarebytes.com
   e.crashlytics.com
   clickserve.dartsearch.net
   ad.doubleclick.net
   stat.nate.com
   cyad1.nate.com
   nate.com
   ichnaea.netflix.com
   graph.instagram.com
   stats.appsflyer.com
   device-api.urbanairship.com
   gurgle.zdbb.net
   fastlane.rubiconproject.com
   incoming.telemetry.mozilla.org
   mcafee12.tt.omtrdc.net
   etoro.com
   google-analytics.com
   googleadservices.com
   googletagmanager.com
   googletagservices.com
   samsungotn.net
   f1.media.brightcove.com
   metrics.fe.apple-dns.net
   stocks-analytics-events.apple.com
   js-agent.newrelic.com
   ssl.google-analytics.com
   bam.nr-data.net
   doubleclick.com
   www.google-analytics.com
   d.xp1.ru4.com
   www.googleadservices.com
   fls-eu.amazon.com
   pagead2.googlesyndication.com
   srx.main.ebayrtm.com
   pixel.everesttech.net
   ssl2anyone3.com
   rainydaymarketing.go2affise.com
   r.remarketingpixel.com
   t.paypal.com
   aax-eu.amazon-adsystem.com
   googleads.g.doubleclick.net
   assets.adobedtm.com
   csi.gstatic.com
   tracker.affirm.com
   adservice.google.com
   www.googletagmanager.com
   cdn-eu-ec.yottaa.net
   try.abtasty.com
   dcinfos.abtasty.com
   www.dwin1.com
   www.upsellit.com
   tags.tiqcdn.com
   alb.reddit.com
   log.olark.com
   cdn.optimizely.com
   www-google-analytics.l.google.com
   profile.localytics.com
   analytics.localytics.com
   engage1.silverpop.com
   reports.crashlytics.com
   settings.crashlytics.com
   ip-api.com
   pro.ip-api.com
   api.amplitude.com
   app.pendo.io
   cdn.ravenjs.com
   va.tawk.to
   widget.privy.com
-rw-r--r-- 1 root root 1383 Jan 16 12:14 /etc/dnsmasq.d/01-pihole.conf
   user=pihole
   group=pihole
   localise-queries
   no-resolv
   cache-size=10000
   log-queries
   local-ttl=2
   log-async
   interface=eth0
-rw-r--r-- 1 root root 3102 Jan 16 12:13 /etc/lighttpd/lighttpd.conf
   server.modules = (
   	"mod_access",
   	"mod_accesslog",
   	"mod_auth",
   	"mod_expire",
   	"mod_compress",
   	"mod_redirect",
   	"mod_setenv",
   	"mod_rewrite"
   server.error-handler-404    = "pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1704 Jan 16 12:13 /etc/cron.d/pihole
   25 4   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   57 15  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 315 Jan 16 12:18 /var/log/lighttpd/error.log
   2019-01-13 06:25:02: (server.c.1534) logfiles cycled UID = 0 PID = 1464
   2019-01-16 12:14:09: (server.c.1828) server stopped by UID = 0 PID = 1
   2019-01-16 12:14:10: (log.c.217) server started
   2019-01-16 12:17:48: (server.c.1828) server stopped by UID = 0 PID = 1
   2019-01-16 12:18:05: (log.c.217) server started
-rw-r--r-- 1 pihole pihole 10022 Jan 16 12:20 /var/log/pihole-FTL.log
   [2019-01-16 12:14:22.309] Using log file /var/log/pihole-FTL.log
   [2019-01-16 12:14:22.309] ########## FTL started! ##########
   [2019-01-16 12:14:22.309] FTL branch: master
   [2019-01-16 12:14:22.309] FTL version: v4.1.2
   [2019-01-16 12:14:22.309] FTL commit: b06eedf
   [2019-01-16 12:14:22.309] FTL date: 2018-12-21 14:43:34 -0600
   [2019-01-16 12:14:22.309] FTL user: pihole
   [2019-01-16 12:14:22.309] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
   [2019-01-16 12:14:22.309]    SOCKET_LISTENING: only local
   [2019-01-16 12:14:22.310]    AAAA_QUERY_ANALYSIS: Show AAAA queries
   [2019-01-16 12:14:22.310]    MAXDBDAYS: max age for stored queries is 365 days
   [2019-01-16 12:14:22.310]    RESOLVE_IPV6: Resolve IPv6 addresses
   [2019-01-16 12:14:22.310]    RESOLVE_IPV4: Resolve IPv4 addresses
   [2019-01-16 12:14:22.310]    DBINTERVAL: saving to DB file every minute
   [2019-01-16 12:14:22.310]    DBFILE: Using /etc/pihole/pihole-FTL.db
   [2019-01-16 12:14:22.310]    MAXLOGAGE: Importing up to 24.0 hours of log data
   [2019-01-16 12:14:22.310]    PRIVACYLEVEL: Set to 0
   [2019-01-16 12:14:22.310]    IGNORE_LOCALHOST: Show queries from localhost
   [2019-01-16 12:14:22.310]    BLOCKINGMODE: Null IPs for blocked domains
   [2019-01-16 12:14:22.310]    REGEX_DEBUGMODE: Inactive
   [2019-01-16 12:14:22.310]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
   [2019-01-16 12:14:22.310]    DBIMPORT: Importing history from database
   [2019-01-16 12:14:22.310]    PIDFILE: Using /var/run/pihole-FTL.pid
   [2019-01-16 12:14:22.310]    PORTFILE: Using /var/run/pihole-FTL.port
   [2019-01-16 12:14:22.310]    SOCKETFILE: Using /var/run/pihole/FTL.sock
   [2019-01-16 12:14:22.310]    WHITELISTFILE: Using /etc/pihole/whitelist.txt
   [2019-01-16 12:14:22.310]    BLACKLISTFILE: Using /etc/pihole/black.list
   [2019-01-16 12:14:22.310]    GRAVITYFILE: Using /etc/pihole/gravity.list
   [2019-01-16 12:14:22.310]    REGEXLISTFILE: Using /etc/pihole/regex.list
   [2019-01-16 12:14:22.310]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
   [2019-01-16 12:14:22.310]    AUDITLISTFILE: Using /etc/pihole/auditlog.list
   [2019-01-16 12:14:22.310] Finished config file parsing
   [2019-01-16 12:14:22.311] Skipping empty regex filter on line 1
   [2019-01-16 12:14:22.311] Compiled 2 Regex filters and 96 whitelisted domains in 0.5 msec (0 errors)
   [2019-01-16 12:14:22.312] Database successfully initialized
   [2019-01-16 12:18:09.171] Compiled 2 Regex filters and 96 whitelisted domains in 1.9 msec (0 errors)
   [2019-01-16 12:18:09.201] Database successfully initialized
   [2019-01-16 12:18:09.220] Notice: Increasing queries struct size from 0 to 10000
   [2019-01-16 12:18:09.220] Notice: Increasing domains struct size from 0 to 1000
   [2019-01-16 12:18:09.220] Notice: Increasing clients struct size from 0 to 10
   [2019-01-16 12:18:09.220] New forward server: 127.0.0.1 (0/0)
   [2019-01-16 12:18:09.220] Notice: Increasing forwarded struct size from 0 to 4
   [2019-01-16 12:18:09.221] Notice: Increasing overTime struct size from 0 to 100
   [2019-01-16 12:18:09.234] Notice: Increasing clients struct size from 10 to 20
   [2019-01-16 12:18:09.294] Notice: Increasing domains struct size from 1000 to 2000
   [2019-01-16 12:18:09.317] Notice: Increasing queries struct size from 10000 to 20000
   [2019-01-16 12:18:09.364] Notice: Increasing overTime struct size from 100 to 200
   [2019-01-16 12:18:09.427] Notice: Increasing queries struct size from 20000 to 30000
   [2019-01-16 12:18:09.451] Imported 21207 queries from the long-term database
   [2019-01-16 12:18:09.452]  -> Total DNS queries: 21207
   [2019-01-16 12:18:09.452]  -> Cached DNS queries: 2133
   [2019-01-16 12:18:09.452]  -> Forwarded DNS queries: 16688
   [2019-01-16 12:18:09.452]  -> Exactly blocked DNS queries: 1616
   [2019-01-16 12:18:09.452]  -> Unknown DNS queries: 770
   [2019-01-16 12:18:09.452]  -> Unique domains: 1655
   [2019-01-16 12:18:09.452]  -> Unique clients: 16
   [2019-01-16 12:18:09.452]  -> Known forward destinations: 1
   [2019-01-16 12:18:09.452] Successfully accessed setupVars.conf
   [2019-01-16 12:18:09.462] PID of FTL process: 614
   [2019-01-16 12:18:09.462] Listening on port 4711 for incoming IPv4 telnet connections
   [2019-01-16 12:18:09.462] Listening on port 4711 for incoming IPv6 telnet connections
   [2019-01-16 12:18:09.463] Listening on Unix socket
   [2019-01-16 12:18:09.466] Skipping empty regex filter on line 1
   [2019-01-16 12:18:09.467] Compiled 2 Regex filters and 96 whitelisted domains in 0.6 msec (0 errors)
   [2019-01-16 12:18:09.468] /etc/pihole/black.list: parsed 0 domains (took 0.0 ms)
   [2019-01-16 12:18:09.468] /etc/pihole/gravity.list: parsed 0 domains (took 0.0 ms)
   [2019-01-16 12:20:24.877] Skipping empty regex filter on line 1
   [2019-01-16 12:20:24.877] Compiled 2 Regex filters and 96 whitelisted domains in 0.6 msec (0 errors)
   [2019-01-16 12:20:24.878] /etc/pihole/black.list: parsed 0 domains (took 0.0 ms)
   [2019-01-16 12:20:24.878] /etc/pihole/gravity.list: parsed 0 domains (took 0.0 ms)
*** [ DIAGNOSING ]: Locale
    LANG=en_GB.UTF-8
-rw-r--r-- 1 pihole pihole 5329260 Jan 16 12:29 /var/log/pihole.log
   -----head of pihole.log------
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 query[A] plex.tv from 10.1.1.40
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 forwarded plex.tv to 127.0.0.1
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 63.32.24.1
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 63.32.153.75
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 52.16.193.193
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 52.30.248.117
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 54.72.69.247
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 54.76.102.118
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 54.77.150.142
   Jan 16 00:00:05 dnsmasq[619]: 443760 10.1.1.40/51787 reply plex.tv is 54.246.140.185
   Jan 16 00:00:16 dnsmasq[619]: 443761 10.1.1.118/52780 query[A] www.privateinternetaccess.com from 10.1.1.118
   Jan 16 00:00:16 dnsmasq[619]: 443761 10.1.1.118/52780 forwarded www.privateinternetaccess.com to 127.0.0.1
   Jan 16 00:00:16 dnsmasq[619]: 443761 10.1.1.118/52780 reply www.privateinternetaccess.com is <CNAME>
   Jan 16 00:00:16 dnsmasq[619]: 443761 10.1.1.118/52780 reply privateinternetaccess.com.edgekey.net is <CNAME>
   Jan 16 00:00:16 dnsmasq[619]: 443761 10.1.1.118/52780 reply e14857.ksd.akamaiedge.net is 23.214.161.118
   Jan 16 00:00:21 dnsmasq[619]: 443762 10.1.1.118/59614 query[A] api-0.core.keybaseapi.com from 10.1.1.118
   Jan 16 00:00:21 dnsmasq[619]: 443762 10.1.1.118/59614 forwarded api-0.core.keybaseapi.com to 127.0.0.1
   Jan 16 00:00:21 dnsmasq[619]: 443762 10.1.1.118/59614 reply api-0.core.keybaseapi.com is 52.206.151.214
   Jan 16 00:00:21 dnsmasq[619]: 443762 10.1.1.118/59614 reply api-0.core.keybaseapi.com is 52.201.34.133
   Jan 16 00:00:25 dnsmasq[619]: 443763 10.1.1.124/64566 query[A] news.iadsdk.apple.com from 10.1.1.124
pi@p1:~ $
Temporarily edit /etc/resolv.conf with an external DNS server. Then run pihole -g. Do you still have the issue after this?
