I've set up List item a server using Pi-hole and Unbound for ad-blocking, combined with a VPN server (all running on AWS in Japan). I'm experiencing some unusual behavior with different client configurations:
- When "Allowed IPs" is set to "10.218.170.1/32" on the client:
- VPN works
- Region shows as Canada (despite the server being in Japan)
- Ad-blocking seems to function correctly
- When "Allowed IPs" is changed to "0.0.0.0/0" on the client:
- VPN works
- Region correctly shows as Japan
- Ad-blocking stops working
I'm confused about why changing the "Allowed IPs" setting affects both the perceived region and the ad-blocking functionality.
Questions:
- Why does the region appear as Canada with the more restrictive IP setting?
- Why does ad-blocking stop working when I use "0.0.0.0/0" as the Allowed IPs?
- How can I configure the client to use the correct region (Japan) while ensuring that ad-blocking remains functional?
Any insights or suggestions on how to troubleshoot this issue would be greatly appreciated. Thank you!
