Issue with Pi-Hole on Ubuntu and port 53
FTL web service should be running
FTL web service is showing "FTL offline" but the service is running. I believe this is an issue with port 53
https://ticoder.pi-hole.net/6bez9yqrww
I attempted to disable the dnsmasq to see if that was causing the issue
sudo systemctl stop dnsmasq
sudo systemctl restart pihole-FTL.service
That didn't change anything
I think the FTL service is running:
pihole-FTL.service - LSB: pihole-FTL daemon
Loaded (/etc/init.d/pihole-FTL; generated)
Active: active (exited) since Wed 2019xxxxxxxxxxxxxxxxxxxxxxxx
Process: 9434 ExecStop=/etc/init.d/pihole-FTL stop (code=excited, status=0/SUCCESS)
Process: 9450 ExecStart=/etc/init.d/pihole-FTL start (code=excited, status=0/SUCCESS)
sudo netstat -nltup | grep :53
Shows me a service called "named" with PID 1011 that is on the IP address that I need but if I kill that process then the DNS stops working.
That's exactly what's taking over port 53 (required for DNS0 and not letting Pi-hole use it.
See:
That should fix your issue.
