Hi
The issue I am facing:
I can't add additional blocklists to pi-hole v5. I don't have /etc/pihole/adlists.list on my system.
Details about my system:
OS DietPi v6.30.0
Pi-hole Version v5.0 Web Interface Version v5.0 FTL Version v5.0
Stock Install
Thanks For The Help
This list is not used any longer since v5.0 but instead the database gravity.db
is.
You can add adlists by adding them via web interface, pihole -a adlist add URL comment
or via direct sql injection.
jfb
3
This has some details for adding lists from the admin GUI.
Thanks, I added them by using the guide you posted.
