Hi All,
Please help me. When i configure Pihole like primary DNS on router. It can not ping any device.
If I dont use pihole like primary dns all works fine.
ip addr
4: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
link/ether 9c:eb:e8:60:ea:9c brd ff:ff:ff:ff:ff:ff
inet 192.168.1.9/24 brd 192.168.1.255 scope global eth0
inet6 fe80::9eeb:e8ff:fe60:ea9c/64 scope link
ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
--- 192.168.1.1 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2000ms
cat /etc/resolv.conf
**# Generated by dhcpcd from eth0**
**# /etc/resolv.conf.head can replace this line**
nameserver 127.0.0.1
**# /etc/resolv.conf.tail can replace this line**
ip route
default via 192.168.1.1 dev eth0 metric 204
default via 192.168.1.1 dev eth0 proto static metric 1024
169.254.0.0/16 dev eth0 scope link metric 1000
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.9 metric 204
192.168.1.9 via 127.0.0.1 dev lo metric 204
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2017-12-10:17:04:00 debug log has been initiated.
[i] Core: v3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.2-0-g5ba4135
[i] Web: v3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.2-0-gf74cd82
[✓] FTL: vDev-437af07 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.72
[i] 1.4.35
[i] 5.6.30
[✓] Debian GNU/Linux 8 (jessie)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
/opt/pihole/piholeDebug.sh: line 474: $'[\E[32m✓\E[0m] \E[32marmv7l\E[0m': command not found
192.168.1.9/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::9eeb:e8ff:fe60:ea9c does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
192.168.1.1
* Pinging 192.168.1.1
192.168.1.1...
[] is in use by
[22] is in use by sshd
[53] is in use by dnsmasq
[80] is in use by lighttpd
[6010] is in use by sshd
[✓] ddlsoftdirectdlw.com is 192.168.1.9 via localhost (127.0.0.1)
[✓] ddlsoftdirectdlw.com is 192.168.1.9 via Pi-hole (192.168.1.9)
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.9/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
DNSMASQ_LISTENING=single
PIHOLE_DNS_1=194.50.85.5
PIHOLE_DNS_2=194.50.85.7
DNS_FQDN_REQUIRED=false
DNS_BOGUS_PRIV=false
DNSSEC=true
[✗] X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Date: Sun, 10 Dec 2017 15:07:19 GMT
Server: lighttpd/1.4.35
[✓] X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 23579643 Dec 10 15:32 /etc/pihole/gravity.list
192.168.1.9 0.0.0.0
192.168.1.9 000000-0.000webhostapp.com
192.168.1.9 0-0-0-0-0-0proxy.tserv.se
192.168.1.9 000007.ru
192.168.1.9 vipcasinoline.com
192.168.1.9 vipcasinovip.net
192.168.1.9 vipcheats.us
192.168.1.9
-rw-r--r-- 1 root root 633 Dec 10 15:22 /etc/pihole/adlists.default
-rw-r--r-- 1 root root 2625 Nov 27 23:14 /etc/pihole/adlists.list
https://hosts-file.net/grm.txt
https://reddestdream.github.io/Projects/MinimalHosts/etc/MinimalHostsBlocker/minimalhosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/KADhosts/hosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Spam/hosts
https://v.firebog.net/hosts/static/w3kbl.txt
https://adaway.org/hosts.txt
https://v.firebog.net/hosts/AdguardDNS.txt
https://v.firebog.net/hosts/Easylist.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/SpotifyAds/hosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/UncheckyAds/hosts
https://v.firebog.net/hosts/Airelle-trc.txt
https://v.firebog.net/hosts/Easyprivacy.txt
https://v.firebog.net/hosts/Prigent-Ads.txt
https://raw.githubusercontent.com/quidsup/notrack/master/trackers.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.2o7Net/hosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/tyzbit/hosts
https://v.firebog.net/hosts/Airelle-hrsk.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt
https://hosts-file.net/exp.txt
https://hosts-file.net/emd.txt
https://hosts-file.net/psh.txt
https://mirror.cedia.org.ec/malwaredomains/immortal_domains.txt
https://www.malwaredomainlist.com/hostslist/hosts.txt
https://bitbucket.org/ethanr/dns-blacklists/raw/8575c9f96e5b4a1308f2f12394abd86d0927a4a0/bad_lists/Mandiant_APT1_Report_Appendix_D.txt
https://v.firebog.net/hosts/Prigent-Malware.txt
https://v.firebog.net/hosts/Prigent-Phishing.txt
https://raw.githubusercontent.com/quidsup/notrack/master/malicious-sites.txt
https://ransomwaretracker.abuse.ch/downloads/RW_DOMBL.txt
https://v.firebog.net/hosts/Shalla-mal.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Risk/hosts
-rw-r--r-- 1 root root 38 Dec 10 15:32 /etc/pihole/local.list
192.168.1.9 wrath
192.168.1.9 pi.hole
-rw-r--r-- 1 root root 234 Dec 10 15:21 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 252 Nov 27 23:16 /etc/pihole/whitelist.txt
mirror1.malwaredomains.com
sysctl.org
zeustracker.abuse.ch
s3.amazonaws.com
hosts-file.net
v.firebog.net
adaway.org
mirror.cedia.org.ec
bitbucket.org
-rw-r--r-- 1 root root 1608 Dec 10 16:30 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=194.50.85.5
server=194.50.85.7
dnssec
trust-anchor=.,19036,8,2,49AAC11D7B6F6446702E54A1607371607A1A41855200FD2CE1CDDE32F24E8FB5
interface=eth0
-rw-r--r-- 1 root root 3027 Dec 10 15:21 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1418 Dec 10 15:21 /etc/cron.d/pihole
2 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker
-rw-r--r-- 1 www-data www-data 3063 Dec 10 16:38 /var/log/lighttpd/error.log
2017-11-27 21:08:30: (log.c.164) server started
2017-11-27 21:09:01: (server.c.1558) server stopped by UID = 0 PID = 1
2017-11-27 21:09:02: (log.c.164) server started
2017-11-27 21:10:29: (server.c.1558) server stopped by UID = 0 PID = 1
2017-11-27 21:10:51: (log.c.164) server started
2017-11-27 21:11:57: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Notice: Undefined variable: timestamp in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 79
2017-11-27 21:18:41: (server.c.1558) server stopped by UID = 0 PID = 1
2017-11-27 21:19:11: (log.c.164) server started
2017-11-27 21:50:38: (server.c.1558) server stopped by UID = 0 PID = 1
2017-11-27 21:51:10: (log.c.164) server started
2017-12-01 00:17:19: (log.c.164) server started
2017-12-09 23:19:58: (server.c.1558) server stopped by UID = 0 PID = 1
2017-12-09 23:20:30: (log.c.164) server started
2017-12-09 23:25:52: (server.c.1558) server stopped by UID = 0 PID = 1
2017-12-09 23:26:22: (log.c.164) server started
2017-12-09 23:30:14: (server.c.1558) server stopped by UID = 0 PID = 1
2017-12-09 23:30:44: (log.c.164) server started
2017-12-10 14:57:47: (server.c.1558) server stopped by UID = 0 PID = 1
2017-12-10 14:57:49: (log.c.164) server started
2017-12-10 15:04:35: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Notice: Undefined index: tab in /var/www/html/admin/settings.php on line 231
2017-12-10 15:06:06: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Notice: Undefined index: tab in /var/www/html/admin/settings.php on line 231
2017-12-10 15:30:01: (server.c.1558) server stopped by UID = 0 PID = 1
2017-12-10 15:30:03: (log.c.164) server started
2017-12-10 15:17:19: (log.c.164) server started
-rw-r--r-- 1 pihole pihole 18026 Dec 10 16:39 /var/log/pihole-FTL.log
[2017-12-10 15:17:27.019]
[2017-12-10 15:17:27.019] FTL branch: (no branch)
[2017-12-10 15:17:27.019] FTL hash: v2.12
[2017-12-10 15:17:27.041] FTL date: 2017-12-06 21:35:44 -0600
[2017-12-10 15:17:27.041] FTL user: pihole
[2017-12-10 15:17:27.091] Notice: Found no readable FTL config file
[2017-12-10 15:17:27.100] Using default settings
[2017-12-10 15:17:27.100] Starting config file parsing
[2017-12-10 15:17:27.100] SOCKET_LISTENING: only local
[2017-12-10 15:17:27.100] TIMEFRAME: Rolling 24h
[2017-12-10 15:17:27.100] QUERY_DISPLAY: Show queries
[2017-12-10 15:17:27.100] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2017-12-10 15:17:27.100] MAXDBDAYS: max age for stored queries is 365 days
[2017-12-10 15:17:27.100] RESOLVE_IPV6: Resolve IPv6 addresses
[2017-12-10 15:17:27.101] RESOLVE_IPV4: Resolve IPv4 addresses
[2017-12-10 15:17:27.101] Finished config file parsing
[2017-12-10 15:17:27.184] Found no other running pihole-FTL process
[2017-12-10 15:17:27.283] PID of FTL process: 508
[2017-12-10 15:17:37.532] Gravity list entries: 694584
[2017-12-10 15:17:37.532] No blacklist present
[2017-12-10 15:17:37.533] No wildcard blocking list present
[2017-12-10 15:17:37.585] Database initialized
[2017-12-10 15:17:37.585] Starting initial log file parsing
[2017-12-10 15:17:37.586] Reading from /var/log/pihole.log.1 (rw-r--r--)
[2017-12-10 15:17:37.589] Notice: Increasing queries struct size from 0 to 10000 (320.10 KB)
-rw-r--r-- 1 dnsmasq root 398220 Dec 10 17:07 /var/log/pihole.log
-----head of pihole.log------
Dec 10 15:17:14 dnsmasq[312]: started, version 2.72 cachesize 10000
Dec 10 15:17:14 dnsmasq[312]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect
Dec 10 15:17:14 dnsmasq[312]: warning: interface eth0 does not currently exist
Dec 10 15:17:14 dnsmasq[312]: using nameserver 194.50.85.7#53
Dec 10 15:17:14 dnsmasq[312]: using nameserver 194.50.85.5#53
Dec 10 15:17:14 dnsmasq[312]: read /etc/hosts - 5 addresses
Dec 10 15:17:14 dnsmasq[312]: read /etc/pihole/local.list - 2 addresses
Dec 10 15:17:14 dnsmasq[312]: failed to load names from /etc/pihole/black.list: No such file or directory
Dec 10 15:17:50 dnsmasq[312]: bad name at /etc/pihole/gravity.list line 481843
Dec 10 15:17:50 dnsmasq[312]: read /etc/pihole/gravity.list - 481843 addresses
Dec 10 15:17:50 dnsmasq[312]: query[A] 0.ua.pool.ntp.org from 127.0.0.1
Dec 10 15:17:50 dnsmasq[312]: forwarded 0.ua.pool.ntp.org to 194.50.85.7
Dec 10 15:17:50 dnsmasq[312]: forwarded 0.ua.pool.ntp.org to 194.50.85.5
Dec 10 15:17:50 dnsmasq[312]: query[AAAA] 0.ua.pool.ntp.org from 127.0.0.1
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
ip -4 route | grep default | cut -d ' ' -f 3
192.168.1.1
192.168.1.1
cat /etc/dhcpcd.conf
**# A sample configuration for dhcpcd.**
**# See dhcpcd.conf(5) for details.**
**# Inform the DHCP server of our hostname for DDNS.**
hostname
**# Use the hardware address of the interface for the Client ID.**
#clientid
**# or**
**# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.**
**duid**
**# Rapid commit support.**
**# Safe to enable by default because it requires the equivalent option set**
**# on the server to actually work.**
option rapid_commit
**# A list of options to request from the DHCP server.**
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
**# Most distributions have NTP support.**
option ntp_servers
**# Respect the network MTU.**
**# Some interface drivers reset when changing the MTU so disabled by default.**
#option interface_mtu
**# A ServerID is required by RFC2131.**
require dhcp_server_identifier
**# A hook script is provided to lookup the hostname if not set by the DHCP**
**# server, but it should not be run by default.**
nodhcp
nohook lookup-hostname
interface eth0
static ip_address=192.168.1.9/24
static routers=192.168.1.1
cat /etc/hosts
127.0.0.1 wrath
127.0.0.1 pi-hole
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
Thanks for any help.
