Issue running in rootless container
Running Pihole with docker compose w/ podman. Starts with following errors:
pihole  | install: cannot create regular file '/etc/pihole/dhcp.leases': Permission denied
pihole  | chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
pihole  | chown: changing ownership of '/etc/pihole': Permission denied
pihole  | chmod: cannot access '/etc/pihole/dhcp.leases': No such file or directory
pihole  | Stopping pihole-FTL
pihole  | pihole-FTL: no process found
Here is my docker-compose.yml:
pihole:
    container_name: pihole
    image: pihole/pihole:latest
    networks:
      pihole_network:
        ipv4_address: '192.168.50.20'
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
      - "80:80/tcp"
      - "443:443/tcp"
      - "80:80/tcp"
    environment:
      TZ: 'America/Chicago'
      WEBPASSWORD: "*************"
    volumes:
      -  /home/svon/podman/pihole/etc-pihole:/etc/pihole
      -  /home/svon/podman/pihole/etc-dnsmasq.d:/etc/dnsmasq.d
    cap_add:
      - NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
    restart: unless-stopped
networks:
  pihole_network:
    driver: macvlan
    driver_opts:
      parent: enp7s0
    ipam:
      config:
        - subnet: 192.168.50.0/24
          gateway: 192.168.50.1
pihole directories on podman host are 755. in the container:
drwxr-xr-x. 2 1000 pihole 6 Jan 10 20:23 pihole/
I'm quite new to containers in general so apologies if I'm missing something basic or if I can provide more info. Thanks
Actually, the permissions are marked with a dot in the end:
          |_____ This dot
GNU ls uses a "." character to indicate a file with an SELinux
security context, but no other alternate access method.
You need to check why these permissions were set, but I'm almost sure this is causing your issue.
Ahh Thank you! I didn't realize it would take SELinux settings from the host machine. disabling/chaing SElinux permissions was the key
