Thanks a bunch! I've learned a lot so far. I think I eat.
I do hosting. And I access all of my web management through my public IP address. I use my DDNS to access all of my webadmins.. When I am using this method using the router's firmware. I can't use my DDNS name to access all of the devices on my network. If I disconnect from the VPN everything works like normal. While connected to the VPN I have to use all of my local ranges "192.168.x.x" and such.
I can access my network from outside using the DDNS. I just can't do it with a device on my network that is connected with the VPN. I can't use my DDNS to access my internal network locally. But I can without the VPN
I was just wondering. Is there a way to fix this loopback issue while connected to the VPN through the router?
This is more of an annoyance than it is a necessary fix. But it would be nice to know how to fix this because it's just one of those things I haven't figured out yet..
Thanks again everyone for all the help. Really.
Never used DDNS but maybe worth checking:
route PRINT
and
nslookup pi.hole
Is that information you want me to post or is that just a place you suggest I look?
Both.
I dont understand, looking at nslookup command, Pi-Hole working for you if your Windows DNS address is not pointing to that of the Pi-Hole DNS service?
EDIT: but obviously it does resolve via Pi or it wouldnt return IP
Not sure but looks like you miss default route/gateway once connected.
To add a default route using the VPN interface:
route add 0.0.0.0 mask 0.0.0.0 172.21.22.203
Check with:
route print
To delete the default route again if not working:
route delete 0.0.0.0 mask 0.0.0.0
Sorry i see now, you already got default gw:
0.0.0.0 0.0.0.0 65.x.x.x ....
I'm still working out a few kinks. But I just wanted to thank you and everyone for all the pointers. They helped a lot.
Man this really sucks ..... This is way too much hassle to go through just to make a VPN work with Pi-hole
Who has the time for all this?
It kind of defeats the main purpose of computers, making your life easier ...... I'm sure that will get some panties in a twist but it's the truth none the less
