retrieve 1 ptr query every ten seconds from 00:00 (log recycle) to 13:53:45 and then nothing more.
While I was writing this message, I check again and the issue restart at 15:00:00 : every ten seconds up to now.
Dec 1 15:12:07
Dec 1 15:12:17
Dec 1 15:12:27
Dec 1 15:12:37
Dec 1 15:12:47
Dec 1 15:12:57
Dec 1 15:13:07
Dec 1 15:13:17
Dec 1 15:13:27
Dec 1 15:13:37
Dec 1 15:33:38 dnsmasq[670]: query[PTR] c.1.2.3.6.b.2.e.f.6.e.0.8.c.8.4.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:33:48 dnsmasq[670]: query[PTR] 7.2.f.0.6.0.c.d.c.4.f.3.c.d.c.e.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:33:58 dnsmasq[670]: query[PTR] 4.0.9.6.7.2.2.4.8.b.d.4.3.f.9.6.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:34:08 dnsmasq[670]: query[PTR] 9.b.a.f.3.4.8.4.9.f.a.e.0.f.4.e.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:34:19 dnsmasq[670]: query[PTR] 7.7.c.4.e.a.4.7.d.4.3.0.3.a.d.c.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:34:29 dnsmasq[670]: query[PTR] e.8.3.4.3.5.3.a.f.a.4.5.3.a.f.a.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:34:39 dnsmasq[670]: query[PTR] a.6.7.0.f.4.d.a.1.f.8.b.6.9.5.6.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:34:49 dnsmasq[670]: query[PTR] f.4.b.3.5.0.6.f.c.1.4.c.4.3.d.b.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:34:59 dnsmasq[670]: query[PTR] f.b.5.3.4.8.0.5.1.c.f.7.2.6.4.e.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:35:09 dnsmasq[670]: query[PTR] 6.9.c.d.9.6.4.4.6.5.5.d.9.a.8.2.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:35:19 dnsmasq[670]: query[PTR] 0.6.d.1.7.9.0.b.c.c.1.1.6.3.9.f.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:35:29 dnsmasq[670]: query[PTR] 5.c.c.b.5.0.3.c.7.0.2.5.b.4.e.9.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:35:39 dnsmasq[670]: query[PTR] b.f.e.0.6.c.0.6.5.a.a.6.f.e.4.7.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:35:49 dnsmasq[670]: query[PTR] b.b.3.2.d.3.f.1.5.f.6.e.9.4.0.f.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:35:59 dnsmasq[670]: query[PTR] c.d.9.8.5.5.8.3.7.5.1.9.2.9.b.2.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:36:09 dnsmasq[670]: query[PTR] b.3.5.7.0.f.3.c.6.6.4.e.1.5.9.d.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:36:19 dnsmasq[670]: query[PTR] 6.7.f.5.c.e.8.f.9.2.d.b.c.b.0.1.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:36:29 dnsmasq[670]: query[PTR] f.e.6.4.6.d.a.6.2.9.8.a.e.5.c.c.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:36:39 dnsmasq[670]: query[PTR] 5.4.2.3.1.5.8.f.1.2.2.3.0.4.0.7.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:36:49 dnsmasq[670]: query[PTR] 6.1.1.f.e.0.c.c.8.9.7.2.c.e.1.2.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:36:59 dnsmasq[670]: query[PTR] 9.7.6.7.5.5.e.7.4.3.e.8.3.e.0.5.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:37:09 dnsmasq[670]: query[PTR] c.f.1.e.6.e.0.3.0.f.c.b.d.3.8.e.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:37:19 dnsmasq[670]: query[PTR] 8.a.c.3.f.b.8.4.2.7.f.a.a.d.c.d.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:37:29 dnsmasq[670]: query[PTR] c.e.6.0.e.b.9.4.e.7.c.3.8.a.7.c.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:37:40 dnsmasq[670]: query[PTR] 9.1.d.d.b.c.4.d.4.8.f.a.c.8.d.c.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:37:50 dnsmasq[670]: query[PTR] 2.2.d.4.1.f.2.4.3.6.0.4.9.1.3.e.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:38:00 dnsmasq[670]: query[PTR] 107.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 15:38:10 dnsmasq[670]: query[PTR] 1.6.3.2.4.4.9.f.f.3.5.b.6.8.c.0.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Dec 1 15:38:20 dnsmasq[670]: query[PTR] c.b.6.b.4.2.6.1.9.d.0.0.c.d.0.a.0.a.0.A.B.C.D.E.F.G.H.I.J.a.2.ip6.arpa from 127.0.0.1
Can it be that one of your devices is using a new IPv6 address every ten seconds? This seems to be the only explanation as Pi-hole itself is doing PTR lookups only for clients and upstream servers.
Try setting
RESOLVE_IPV6=no
in /etc/pihole/pihole-FTL.conf followed by a
pihole restartdns
to tell FTL that you don't want host names for IPv6 addresses. This may not yet work in all cases, but we're looking at releasing a small update for this scenario in a few hours. Watch for FTL v5.3.2
Restarting dns server solve the problem. With RESOLVE_IPV6=NO or YES, no more PTR queries flooding.
Some queries remains (both v4 and v6) but very few ; even though "never forward reverse lookups for priv IP range" is checked.
Dec 1 16:09:00 dnsmasq[12027]: query[PTR] 123.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:09:00 dnsmasq[12027]: query[PTR] 130.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:09:00 dnsmasq[12027]: query[PTR] 88.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:09:00 dnsmasq[12027]: query[PTR] 10.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:09:00 dnsmasq[12027]: query[PTR] 124.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:15:00 dnsmasq[12437]: query[PTR] 123.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:15:00 dnsmasq[12437]: query[PTR] b.f.5.e.0.0.d.a.b.a.3.d.7.f.9.b.A.B.C.D.E.F.G.H.I.J.0.a.2.ip6.arpa from 127.0.0.1
Dec 1 16:15:00 dnsmasq[12437]: query[PTR] f.0.d.a.3.7.6.6.d.7.e.7.3.c.d.b.A.B.C.D.E.F.G.H.I.J.0.a.2.ip6.arpa from 127.0.0.1
Dec 1 16:15:00 dnsmasq[12437]: query[PTR] 130.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:15:00 dnsmasq[12437]: query[PTR] 88.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:15:00 dnsmasq[12437]: query[PTR] 10.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:15:00 dnsmasq[12437]: query[PTR] 124.1.168.192.in-addr.arpa from 127.0.0.1
Dec 1 16:25:00 dnsmasq[12437]: query[PTR] 146.1.168.192.in-addr.arpa from 127.0.0.1
Aaaand... issue restart at 17:00:00 (both v4 and v6). Doesnt matter, I will wait for next release.
But maybe it's the same issue than "Pi-hole Reverse DNS queries every hour". For some users, it lasts few minutes ; for others, it's longer.
I agree that it may be the same issue. Until your last messages, I thought it's precisely doing one query for a different IP every ten seconds. That would have been something separate. I think that's still correct looking at the older posts, however, you are apparently also experiencing the other issue.
I will try your solution but before, I want to purge the network_addresses table. One of my clients is registered in this table with 114 ip adresses !
From my understanding, FTL parse this table each hour and query ptr for each entry. I would like to see if, with a clean table (2 or 3 addresses per client), this process would be quicker.
Issue will still be there, but quicker.
After purge on the network_addresses table :
FTL still query PTR every hour at HH:00:00
1 PTR query every ten seconds
BUT the table contains now 60 rows (instead of 470) so PTR queries only run for 9 min maximum (instead of the whole hour, which overflow on the next hour, etc.).
Commands used to purge table :
logout from web admin interface
sudo systemctl stop pihole-FTL.service
pihole status //check if FTL is correctly stopped
sudo sqlite3 /etc/pihole/pihole-FTL.db "DELETE FROM network_addresses WHERE (ip LIKE '2a01:AAAA:BBBB:CCCC:%' AND lastSeen < (SELECT strftime('%s','2020-12-01')));"
sudo systemctl start pihole-FTL.service
-> only catch SLAAC addresses from router prefix advertised
-> exclude link local fe80::/10 and ipv4 addresses
-> addresses seen before the first december (dont delete fresh addresses)
