I have a rpi 4, running raspian, updated yesterday.
PiHole is running in a docker container, using the docker-compose script shown on the github page (also below). Everything seems to be OK (see debug log token below), but it looks like ipv6 isn't working. The host system has ipv6 enabled, and seemingly functioning correctly. I haven't yet configured anything else, since I want to resolve this first!
Thanks for PiHole, and for your support!
ipv6 is working in the PiHole container without issues.
In the host environment, if I run ip -o addr | grep eth0, I get:
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
- "80:80/tcp"
environment:
- TZ=${TZ:-'Europe/London'}
- WEBPASSWORD=${WEBPASSWORD}
volumes:
- './etc-pihole:/etc/pihole'
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
cap_add:
- NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
restart: unless-stopped
Note that Docker's IPv6 support could have been breaking network isolation in the past.
It seems Docker tried to address this in the meantime, but it may yet be considered experimental.
Quoting docs.docker.com:
ip6tables enables additional IPv6 packet filter rules, providing network isolation and port mapping. This parameter requires experimental to be set to true .
Thanks for the information @Bucking_Horn. I don't need ipv6 per se, but I was concerned I had an issue before I go down the route of integrating PiHole in my network.
I think I may end up following you down this route, as I need to consider my whole infrastructure here. I have a Linksys wrt3200 currently running the stock firmware, and while it works, I do get issues with the interface software. For example, it starts taking a label from one device, and attaching it to others, and also some hosts show up so I can ssh in, but others don't. I also have a VPS off site which I should be able to close down, but I need to move the functionality from it to local server. So I am considering replacing the Linksys with a protectli device (or similar) running pfSense or opnsense, and then use an older pc I have here as a server. Once I get my head around Proxmox, I can then consider if I need to upgrade the hardware to get the performance I need. Now I am off reddit, I need to find a good forum for home labs!
Sounds like a plan. There are lots of great home lab channels on YouTube. I moved away from locked down routers over 4 years ago and haven't looked back. I went the route of Protectli and landed on Untangle. Then when Untangle was purchased by Arista I moved to pfSense. I built a small 2 node Proxmox cluster with inexpensive 1 liter PC's recommended on the Serve the Home channel. I now have a PiHole instance on each node for redundancy and then all my other services spread between the two. It's a great hobby to have a home lab.
