Your Pi-hole container is fully operational on IPv6:
[✓] www.leonbergery.com.pl is NOERROR on lo (::1)
[✓] No IPv6 address available on eth0
[✓] www.leonbergery.com.pl is NOERROR on eth1 (fd65:99c3:b27:1::2)
[✓] www.leonbergery.com.pl is NOERROR on eth1 (fe80::<redacted>73%eth1)
[✓] No IPv6 address available on eth2
[✓] doubleclick.com is 2a00:1450:4016:809::200e via a remote, public DNS server (2001:4860:4860::8888)
But only your eth1 interface carries IPv6 addresses, your eth0 and eth2 don't:
*** [ DIAGNOSING ]: Network interfaces and addresses
2: eth0@if134: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP
inet 172.19.0.4/16 brd 172.19.255.255 scope global eth0
3: eth1@if146: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP
inet 172.24.0.2/16 brd 172.24.255.255 scope global eth1
inet6 fd65:99c3:b27:1::2/64 scope global flags 02
inet6 fe80::<redacted>73/64 scope link
4: eth2@if157: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP
inet 172.30.9.3/29 brd 172.30.9.7 scope global eth2
The network section of your docker compose differs between v5 and v6:
networks:
# Create the internal network
internal:
ipam:
config:
- subnet: 172.30.9.0/29
ipv6net:
enable_ipv6: true
ipam:
config:
- subnet: fd00:cafe:face:feee::/64
proxy:
external: true
networks:
internal:
ipam:
config:
ipv6net:
driver: bridge # Uses the bridge driver (default for Docker networks)
enable_ipv6: true # Enables IPv6 support for this network
ipam: # IP Address Management (IPAM) configuration
driver: default # Uses Docker's default IPAM driver
proxy:
external: true
You'll notice that your container's matching 172.30.9.3 is tied to eth2, which is one of the interfaces without IPv6.
Why would you require your Pi-hole container to be accessible via IPv6 anyway?
If you don't, configuring your router to not advertise an IPv6 address as local DNS server would allow you to drop IPv6 container configuration.
Clients requesting AAAA records would still get the correct IPv6 address answers, regardless of whether they ask via IPv4.
